need help diagnosing drivetrain noise
Old Mar 27, 2009 | 09:12 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
my car has been making a grinding type of noise when i go over speed bumps or reverse direction. its done this ever since i broke my transmission mount and replaced it with a poly mount. ive checked under the car and there doesnt appear to be any thing rubbing. can anyone help me out?
also, my rear end has started to make noise as well when i make somewhat sharp turns. it has an eaton limited slip differential and motive 3.42 gears that are only about 8 months old so im a bit confused as to why its making noise and why its doing it now. if any of you guys can help with either of these problems, it would be greatly appreciated.
Old Mar 27, 2009 | 09:31 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: need help diagnosing drivetrain noise
is this noise like gears grinding when you miss a shift or something not as profound?
Old Mar 28, 2009 | 02:53 AM
Car: 91 GTA
Axle/Gears: stock
it doesnt sound like gears grinding. it does sound like a metal hitting metal type of sound, almost like the exhaust is rubbing on the bottom of the car whenever the chassis flexes but ive looked and theres no indication of rubbing anywhere.
Old Mar 28, 2009 | 05:49 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check the dust shields on the rear brakes. that might be the sound you are hearing.
Old Mar 28, 2009 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Exhaust pipe on panhard?
JamesC
Old Mar 28, 2009 | 06:30 PM
Car: 91 GTA
Axle/Gears: stock
i havent checked that, but why would that be what im hearing after breaking and replacing a transmission mount?
Old Mar 28, 2009 | 06:32 PM
Car: 91 GTA
Axle/Gears: stock
JamesC
i havent checked this either, but i wouldnt think that would be a problem.
Old Mar 28, 2009 | 06:55 PM
DJP87Z28's Avatar
Broken tack weld and making noise when hitting a bump or rough road.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
