To those looking for 9 bolt gears >>
I found 3:73 gears for the 9 bolt rear through TPIS and also Precision gear lists them on thir site. The set from TPIS is made by Precision gear, so call and figure the better price....TPIS includes the master overhaul set too.
http://www.precisiongear.com/gm-7_3_...verhaul%20Kits
I don't know if this is useful to anyone or not, but I figured that I would share my findings. I know there are other companies selling them, but I have not seen anything advertised elsewhere...
1991 Camaro RS/Z28,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... 13.4 @ 104.8 with a 2:77 rear, no traction, no tuning, no practice. Car is pictured in Chevy High Performance magazine, June 2000 issue.
http://www.geocities.com/jasonsz28us/INDEX.htm
1997 GMC Yukon, 4 wheel drive, leather, loaded, Gibson exhaust, K&N intake, Boston pro series speakers..... That's it so far.
1969 Camaro,12 point cage, total project right now, I am planning an LS1 - T56 - and a Vette independent rear. Pro Touring crowd, look out! 8^)
Car: '85 IROC
The Borg-Warner ratio is 3.70. Even the actual gears are 10:37. I wonder why Myron would call it 3.73?
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Because Miles's gears are custom 41/11. But as he and I agree, that leaves the pinion kinda weak.
Jason, check to see if the gear count is standard or custom. Standard is 37 ring and 10 pinion, while custom setups are (for example Miles) 41 ring and 11 pinion.
George P. Lara
1984 Z28
2001 SS Coming Soon
SCCA, SCFB, SC3GFB
Jason, check to see if the gear count is standard or custom. Standard is 37 ring and 10 pinion, while custom setups are (for example Miles) 41 ring and 11 pinion.------------------
George P. Lara
1984 Z28
2001 SS Coming Soon
SCCA, SCFB, SC3GFB
The ring gear is 37 tooth and the pinion is a 10 tooth on this set.
If you have a 2 series carrier, you need to find a 3 series somewhere, they are out there.
What is the average price for an install, and how long should it take? I have dial indicaters, should I attempt it myself?
Car: 1988 Iroc-z
Engine: L98 350
Transmission: 700-R4
I have the gears and install kit that I would get rid of because I can't send the install kit back.They are $508.00 after shipping to KY.I will take $450.00 obo for them just to not have to worry about selling the install kit later.Send me an E-mail if you are interested.
88 Iroc 38,000 orig miles
free mods,airfoil, afpr,flowmaster,
2.77 gear,top gun 100 shot.
best time et streets
1.79 60ft.
8.41 1/8mile
sprayed88@team.camaroz28.com
1.79 60ft.
8.41 1/8mile
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
If all goes as planned, I will have some new carriers (series 3 of course) and 4.1 gears on the way by the end of the week. Of course, I have thought this before, but it really is close now.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon
www.koolmeister.com
Miles
88 427 Camaro
)www.koolmeister.com
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
88 427 Camaro: Let me know what's up with the gears... I need to upgrade my 9 bolt after putting in the T-56... 3.45's ain't gonna cut it anymore.
Sprayed 88: I sent you a note about your gears.
3.70's/3.73's/4.10's... whatever...
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by Jason Aschle:
</font>
</font>
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
