305 auto ,,needs sorting out
Old Jul 16, 2001 | 06:27 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
1982 305 auto holds in 1st
then changes hard in 2nd at low speed
if you drive it hard it changes normal
no one here has service data on these things
i will put a TH350 in in 6 months but need to drive this thing as is,,,for a while,,,need help,,,,,,,,,,this crapy auto says metric stamped on the pan, and the gearbox looks more suited to a 6 cylinder motor instead of a V8
Old Jul 16, 2001 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TH200C was not the cream of the performance crop, that's for sure. But, the first step towards fixing automatic shifting problems is to change the fluid and filter. If that doesn't help any, you might want to move your transmission change-out up on your schedule.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
jklein337
Sep 19, 2018 06:23 PM
LittleFranks
Sep 17, 2015 12:22 PM
BurlyChev
Aug 22, 2015 01:52 PM
Leggman1
Aug 6, 2015 04:15 AM
