Trani fluid/filter change> HELP
Old Apr 11, 2009 | 09:27 AM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Didn't find anything specific in search: 91' bird, 305TBI, 700R4 trani.... How can I get out all trani fluid. Or do I only change the 2.5quarts that came out of pan? Capacity says 5 quarts? would like to replace all 5 quarts, but don't won't to start car with pan/filter off trani? The sooner I get help, the sooner you can help me enjoy my saturday! THANK YOU!
Old Apr 11, 2009 | 09:46 AM
Re: Trani fluid/filter change> HELP
Disconnected bottom trani line @ radiator... Not much came out there...
Old Apr 11, 2009 | 09:53 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Best way to get it all out is with a pressure flush. Alot is stored in the converter, which won't drain. If you can't flush it, the best alternative would be a few iterations of drain/fill/drain/fill/drain/fill until the old fluid is effectively diluted. Adding a pan drain for doing this makes it simple, without one it's a PITA.
Old Apr 11, 2009 | 09:58 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Total pan capacity should be 5qts if I remember corectly plus what is in the torque convertor . If your convertor has a drain plug remove it to drain out old fluid then put plug back and put in 4-5qts and run the engine to fill to full .
Old Apr 11, 2009 | 10:08 AM
Total trani capacity IS 5qts. but must of it is in the Torque converter like mentioned above and my T.C. doesnt have a plug, nor does my pan.... Bummer.....
Old Apr 11, 2009 | 10:13 AM
Does sound like it's a PITA.... One site suggested putting on new filter/gasket> put pan back on. Fill 2.5quarts > disconnected bottom trani line @ radiator and run for a second to get another quart or 2 out of the T.C. Any opinions on this? should be ok if I shut her down quick and retop off fluid???? Thank you gentleman for your help/opinions!
Old Apr 11, 2009 | 10:15 AM
85MikeTPI's Avatar
Check at your local speed shop.. The trans pan plug kits are cheap and easy to install, especially since you've already got the pan off.. Sometimes I've even ran across them in the chain parts stores.
Old Apr 11, 2009 | 10:16 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Sorry to hear that so you will just have to do like 85MikeTPI said if you want to get all the old fluid out .
Old Apr 11, 2009 | 10:17 AM
85MikeTPI's Avatar
It's doable, but you gotta be quick.. I was amazed how much volume/pressure is pumped out. If you have help, it would be best if someone could stay at the key to turn it off quick..
Old Apr 11, 2009 | 10:22 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Do NOT drain your torque converter if you are not removing it! Putting trans fluid into your transmission will NOT fill it back up!
Are you sure your trans fluid was full when you drained it? It is possible that you may have only had 2.5 quarts in it.
Old Apr 11, 2009 | 10:34 AM
Tranny fluid was full I checked it first.
Old Apr 11, 2009 | 10:52 AM
Filter doesn't seem to want to cooperate! seems like it goes half in, but seems "wobbley". Dont want to force it. Put new fluid on gasket. And yes I removed the old gasket that was stuck up there.... doesnt seem like filter is in their very good????? DISREGARD THIS LAST STATEMENT... GOT THE NEW FILTER IN NOW!
Old Apr 11, 2009 | 11:40 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Good to hear your on your way to getting it done .
Old Apr 11, 2009 | 01:12 PM
Done!<<<< QUESTION THOUGH>>>> How does the trani pull the fluid from the bottom of the pan? I didn't notice a hose feed to the pan, I'm assuming this is normal cause the trani seems good.... Does the system work on a "vacuum"???? Thanks again for all the help!
Old Apr 11, 2009 | 01:25 PM
85MikeTPI's Avatar
The front of the trans that the converter rides in, is a fluid pump. It pulls the fluid up from the pan through the filter you just changed..
Old Apr 11, 2009 | 01:46 PM
Thank you sir! Time to do the fuel filter.... car runs great. Just doing preventive maintenance stuff..........
Old Apr 11, 2009 | 03:47 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Uh, what? Your trans is going to take more like 11-12qts with most in the TC. 5 goes in the pan.
And as for draining the fluid by starting the car with the cooler line disconnected, WTF?!
Old Apr 11, 2009 | 04:26 PM
You are right on the capacity. Thanks for pointing that out for me! Didn't read my manual close enough! I didn't run car with line disconnected. Saw that at another site and for obvious reasons didn't want to chance it! Thought about it though!
Thornburg
Aug 25, 2015 01:46 AM
z28crazy
May 17, 2001 03:18 PM
Stell1579
Jan 13, 2001 09:50 PM
brockrodgers
Jan 11, 2001 06:26 PM
KnightWhoSaysNI83
Dec 25, 2000 07:45 AM
