Any Tips or Tricks to get the top 2 bolts off the tranny?
Old Jul 18, 2001 | 05:28 PM
JucinGTA's Avatar
I read that people have drilled out part of the firewall, and then could get at it from the inside!!I found myself today using this longa$$ extention, with a swivel, NOT FUN!!!! Anybody know any easier ways? O by the way if you are doing on trans on the floor, Rental max rents these awsome Trans jacks for 15 a day!!!
Old Jul 18, 2001 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put the tranny jack up to the tranny, remove the rear mount & crossmember (and distributor cap), then drop the transmission down a few inches. This will allow you to use the extension and swivel socket (vs. u-joint & socket on extension) to get to them more easily.
I'll never willingly do another tranny without a real tranny jack.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 18, 2001 | 07:06 PM
JucinGTA's Avatar
I hear you on that one!!!!!!!
Old Jul 18, 2001 | 07:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a whole lot easier to get them from above with a short 9/16" box wrench. You can just stand there and reach down and get them. Getting to them from under the car is almost something like work.
ICON Motorsports
Old Jul 18, 2001 | 08:05 PM
JucinGTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
HOW I have no space to be shoving a wrench in from the back?
Old Jul 18, 2001 | 08:26 PM
Jay 727's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JucinGTA:
</font>
Do the opposite of what five7kid said- jack the tranny up instead and increase room on top to access the bolts.
It makes it easier also to wrap the swivel with electrical tape and get them from the bottom, I agree it's easier to get them from the bottom after dropping the rear of the trans.
Old Jul 18, 2001 | 09:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I can get the passenger side one with a wrench from the top but the drivers side one needs both. Wrench from the top and swivel socket with long extension from the bottom.
Once it's out, make life easier next time with a big hammer. I beat the firewall to give me a little more room.
Lowering the tranny is still the best way.
Since I have a race car, I'll eventually install a removable tranny tunnel to make removal easier. I just haven't got around to it yet.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 19, 2001 | 09:33 AM
ATOMonkey's Avatar
I have done this many many many times. The top two are taken out from the top, remove the dist first. End of story. Don't try removing the tranny because it's a pain in the a$$ if you break the crossmember bolts, and I've broke plenty without trying. The rest can be taken out from the bottom by using a really long extension and accessing them from the tailshaft. If you don't mind and think you might be doing this quite often then drill holes in the tunnel and get them out from the inside of the car.
BTW This is one of those jobs that just sucks and there's no way around it.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
[This message has been edited by ATOMonkey (edited July 19, 2001).]
Old Jul 19, 2001 | 03:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Another tip- tighten down a bottom engine-to-trans bolt, one on each side. Right now, those top two bolts are taking a ton of stress. Divert some of that stress to the "easy-to-get-to" bottom bolts.
I pulled an auto trans twice, both were on a 2.8 V6, but maybe this'll help you. To reach the top bolts, this is the combination of tools I used. ALL TOOLS WERE 1/2 INCH DRIVE! The 3/8" drive stuff is too thin, and it twists, absorbing your torque.
Socket --- universal joint --- 24 inch extension --- 7 inch extension --- breaker bar
Once those top bolts are out, don't forget to remove the bottom ones again.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 22, 2001 | 10:43 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
it is almost impossible to get the bolts out from the top, with all the wiring BS and the distributer in the way. the way i do it at work is, lower the back of the tranny, almost to the point where the distubuter hits the firewall, then use a 3 ft extenstion with a 9/16 wiggly socket(these things are one of the best tools invented, and alot better than a universal)I have done more tranny swaps at work in the past two months than i care to discuss, and I have found is the easiest/best way to do it. hope this helps.
Wide Open Till You See God...Then Brake
Old Jul 25, 2001 | 05:05 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
What I did was take the dist out, (this works out better when you change the manifold and carb at the same time, like I did, so the dist was already out), but with it out, it gives you plenty of room. Also for more room, leave the bottom bolts in, and make sure everything else is off in the rear, (except the cross member just in case something funky happens)and jack the tail end up, tilting the motor and trans to give more room.
Thornburg
Aug 25, 2015 01:46 AM
Hello, Michael
Aug 20, 2015 03:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
