? about transcooler installation (700r4)
Old Jul 25, 2001 | 08:18 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
does trans fluid enter the rad from bottom line or the top! I was informed by a couple of ppl that it enters from the top yet other ppl said it enters from the bottom just like your cooling system who's right?
BD3
86 IROC mods:retro-fitted to a Comp Cams 210-215 499/499 112 roller cam,T.E.S.,Hooker Aerochamber catback
T.P.I.S. airfoil,Dan Burk ported intake system,,March
pulleys,Accel 8.8wires,ign.mod,Crane PS-91 coil,Crane HI-6S ign.box
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors,PST polygraphite bushings
"The more I learn about women,the more
time & money I spend on my IROC"
Old Jul 25, 2001 | 08:28 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Makes more sense to me that it enters from the top and flows downward. Now that you mention it, I'm not sure though. I can't remember which way I gone and done it...
Old Jul 25, 2001 | 09:27 PM
CrazyRob75's Avatar
undo your top line, put a drain pan underneath andfire the car up for a sec. If the fluidcomes out of the rad, the lower line is the inlet. If it comes out the top line, well that kinda answers itself
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old Jul 25, 2001 | 09:47 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Actually did it the other way...Undid the bottom line and had cooler hooked up but left bottom cooler line off to pump 3qts out only to pump it out of the bottom line onto the strt. Called Pro Built and they confirmed 700r4's inlet bottom return top.
BD3
camaro11j
Sep 19, 2018 08:49 AM
formula_novice
Aug 18, 2015 08:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
fonzie85
Aug 13, 2015 11:50 AM
drathaar907
Aug 6, 2015 04:20 PM
