leaky pan
Old Jul 25, 2001 | 04:04 PM
scott's85T/A's Avatar
leaky pan
some one please tell me a way to get my pan to not leak...I have changed the gasket more than once and it will NOT stop leaking around the front of the pan(drivers side)I have looked but fuond no damage to the tranny that would cause it to leak.I am going to install a new aluminum pan tomarrow and hope that I can correct this,,,should I try to use some sealent??HELP PLEASE!!
Old Jul 25, 2001 | 05:10 PM
ede's Avatar
ede
have you flattened out the dimples around the bolt holes? not over tightened the bolts?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 25, 2001 | 05:39 PM
I'm not sure if they are flat or not I am gona take it off tomarrowWhat should I tighten the new aluminum pans bolts to,,,,about 14 lbs.???Also,, whats the deal with the filter extension that lowers the filter about an inch,,is that just to keep it submerged,seems like that is a heck of an idea,they should all be that way..
Old Jul 28, 2001 | 05:14 AM
transfixleo's Avatar
I assume you are NOT talking about the solid aluminum pans, right? More like the shinny tin pans. First, do NOT use sealant. Second, make sure that it is flat. Third, don't overtighten the pan, use a torque wrench and tighten a cork gasket to 12 ft/lbs or the fiber gasket to 16. Lastly, look ABOVE to see that may actually be the real leak. Remember that gravity and airflow will tend to move the oil from the source to a lower spot and can fool you.
Old Jul 28, 2001 | 10:10 AM
I did have the reg. pan,,but now I have a solid aluminum just havn't gotten around to changing it yet hopefuly today,I know it's the pan I have checked all of the lines, dipstick tube,and so on, and they are all clean and dry,transfixleo-thanks for the help.
Old Jul 28, 2001 | 06:13 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Leo is right, you need to be careful how tight you get those bolts when you use the Cork Gaskets. Most people wrench down untill the cork is pushing out over the edge, and that usually means it has split and will leak.
You never want to use sealant on the trans pan either.
As for the extension, its only needed w/ deeper pans. Even with the shallow pans, the filter is always submerged, you can usually see where the filter sometimes contacts the pan, thats how well its submerged.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 29, 2001 | 12:24 AM
86_Dan_Z28's Avatar
Car: 86 Z28
Do not use the cork gaskets, they are junk. Napa carries a nice filter kit with a rubber gasket, this is made in USA. I will not use any other brand.
Old Jul 29, 2001 | 12:26 AM
breathment's Avatar
why don't u wanna use Sealent on Trans pans?
Old Jul 29, 2001 | 05:23 AM
Quality (the key) cork gaskets are in some cases the best choices. I have never really liked the rubber gaskets that I see and often, when you buy one of the filter and gasket packages the gasket is too thin. Go to a tranny shop and buy a good one.
As to no sealant, first off, it is NOT needed and second it makes a big headache for the next guy who STILL has to fix the leak.
I worked with a guy at the dealer who must have had no luck with pan gaskets and he would put the yellow weather stripping cement on the gaskets. You were better off buying a new pan than spend a 1/2 hour trying to get this stuff off.
Old Jul 30, 2001 | 12:46 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sure its not the shift shaft seal??
These look just like a pan rail leaking.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
timonator
Sep 13, 2015 11:49 AM
