best value Alluminum driveshaft?
Old Apr 18, 2009 | 09:21 AM
IROCBOY's Avatar
anyone have any good or bad experiences with any brand of alluminum driveshaft? i'm looking to upgrade the stock one on my 305/t-5 setup.
Old Apr 18, 2009 | 09:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: best value Alluminum driveshaft?
Why new? Alum shafts are advertised regularly in the classifieds. IIRC, there's one there now.
JamesC
Old Apr 18, 2009 | 09:28 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Best price/performance would be a Used Camaro/Firebird LS1 (98-2002) driveshaft.. They are a perfect fit, balanced for hi-speed, and strong enough for any 305. Check your local yards, or the many LSx focused internet forum classifieds..
Old Apr 19, 2009 | 01:34 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Will the aluminum driveshaft out of the LS1 fit a 305 TPI with an auto tranny?
Do they all have aluminum driveshafts if they have the LS1?
Old Apr 19, 2009 | 02:08 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
If the auto tranny is a 700R4, then yes it should fit. I got one from a 98 TA and it fit my T5 just fine. All the 98-02 LS1's got aluminum driveshafts. Stay away from V-6 driveshafts from the same era - they're 2 piece steel and not compatible with thirdgens AFAIK...
Old Apr 19, 2009 | 02:13 PM
JamesC's Avatar
Yes.
JamesC
Old Apr 19, 2009 | 03:18 PM
85MikeTPI's Avatar
The LS1 A4s are called 4l60e's, but output compatible with the 700R4. The same driveshaft for any (A4 or M6) LS1 4thgen will work in the 3rdgens (A4 or M5 or M6).
Old Apr 20, 2009 | 12:19 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the info to all who replied. I will search the boneyards.
Old Apr 20, 2009 | 02:23 PM
formula310tpi's Avatar
Car: 89 Formula
Axle/Gears: Borg Warner 3.45
I checked the local pontiac dealer and they have 2 listings for the ls1 driveshaft. The only difference between the two is that one has 3.23 rear and the other has no ratio listed. I called the local boneyard and they also wanted to know if the car had 3.23 rear or not.
Has anyone run into this?
Old Apr 20, 2009 | 02:42 PM
85MikeTPI's Avatar
Not sure about the rear ratio difference, or why it should matter..
The piece you're looking for is GM# 12564004
(Dang, I just noticed they want $333 for one on GMPartsDirect now!! I remember buying my first one for $178.... wow)
Old Apr 20, 2009 | 02:46 PM
JamesC's Avatar
The shaft is the same length regardless of gear ratio or transmission. A GM parts man once told me that the so-called 1LE shaft wouldn't fit a manual trans--this after I'd sold more than 60 of them.
JamesC
Old Apr 20, 2009 | 04:58 PM
Car: 89 Formula
Maybe the numerically higher ratio is balanced better. Or maybe the other number is for the 2 piece 6 cyl shaft?
That 4004 number is the one for the 3.23/3.42 ratio shaft. If noone has run into this before, then i won't worry about it. As long as when i go to pick it up, it's aluminum opposed to the steel 2 piece, i should get it, correct?
Old Apr 20, 2009 | 06:22 PM
JamesC's Avatar
Yes.
JamesC
Old Apr 20, 2009 | 06:35 PM
Car: 89 Formula
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
