Who makes a good "H.P." prebuilt 700r4?????
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
or are any of them worth it ???
I need a new 700r so I'm finding my options
thanks
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
thanks
Hecubus
Car: 87 GTA
Engine: 355 Chevy
I wouldnt waste your time with a 700. I went through 3 when my T/A was stock LB9 305. And to think I could have spent a whole lot less if Id gone with a 6-speed after the first 700.... The last and most pricey 700 I had was the TCI street fighter.(JUNK!!) For about 400 more on average you can have a 6-spd.
1987 GTA 355, carbureted, TFS heads(non G2), 6-speed, McLeod clutch, 11.3:1, dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 z-28 wheels, soon to be replacing weak 10 bolt with 12-bolt...gettin tired of breakin axles....
...Whatever turns your tires.....
Car: 91 z82
Engine: 5.0
I would love to have a 6 speed rather than a 700
but what am I looking at for cost and time wise to convert it all ?? just a close guess
and do you think it would even be an option to have it installed ?? or is it going to be way too much?
thanks
Hecubus
thanks
Hecubus
Car: 86 Z28
Car: 91 z82
Engine: 5.0
I've thought about looking into him
it would work out for me too cause I can take out the tranny and that's only a little over 2 hour drive from here
Anyone using a stage 2 tranny from them (Pro-Built) ???
thanks for any help
Hecubus
thanks for any help
Hecubus
Car: 87 GTA
Engine: 355 Chevy
<font face="Verdana, Arial" size="2">Originally posted by Hecubus:
thanks
</font>
thanks
</font>
Car: 91 z82
Engine: 5.0
Everyone will tell you something diferent
Most of whom I've talked to about it agree that A well built 700r4 will be stronger (a few did disagree)
Has anyone any exp. with the Pro-Built 700r4's??
or heard of anything about them???
thanks again
Hecubus
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Trans-Go shift kit
thanks again
Hecubus
Car: 87 GTA
Engine: 355 Chevy
<font face="Verdana, Arial" size="2">Originally posted by Gta-Paladin:
Arent the autos when built stronger though?</font>
I've got a BTE 700R4 that has been great. I've run 12.30's on the motor and 11.70's on nitrous with that trans so far, and it has performed wonderfully.
My $0.02, with any manual trans, it's not a question of whether the trans will fail, but when. Synchros eventually give up the ghost, and require repair. I know three different friends who have each destroyed a T56. The T56 is a strong trans, but they all eventually fail.
RSR
RSR
Linson
Aug 21, 2015 02:12 PM
