Clanking noise from my rear-end
Old Aug 2, 2001 | 12:40 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Anyway, on the car, I just noticed it today during lunch break. I was cruising around the parking lot, looking for a spot and noticed a "clanky" sound coming from the rear axle area. I've heard the rear end whine slightly before and went away so I assumed the worst. But now I don't know for sure. If I give it gas, I can hear a clank and it seems to happen whether I'm turning or not.
Would a rear-axle make this noise before going bad or would it be more like my u-joints finally taking a dump on me?
The rear is an aussie BW 2.77:1 POSI rear. Never had any troubles with it, changed the gear oil twice in it's 104K mile life and yes, I added the posi additive too.
I'm thinking more like U-Joints or could the rear axle also make this type of noise?
I just hope I make the last 7-mile trip home ok ... in the rain ...
IROC-Zone
'88 Camaro IROC-Z 350 TPI
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Aug 3, 2001 | 12:47 AM
MouseCamaro305's Avatar
U-joints could be the problem, have them checked, or if you can, do it yourself, if thats not the problem (which lm sure it is) sometimes the pinion can wiggle itself loose and rub against the carrier, which will make a pretty noticable grinding noise, and usually occurs when youre coming to a stop.
hope this helps a little bit.
good luck finding the problem
Old Aug 3, 2001 | 10:28 AM
Z28DJP1987's Avatar
Bad Possi or axle brgs.
Old Aug 3, 2001 | 03:35 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Hopefully, if it doesn't rain much, I'll be popping off the rear cover and looking at the gears and such in the rear. Anything to look out for. I am pretty new when it comes to rear axle so please forgive my ignorance. I will most definitely check the U-Joints as well. Any tricks to ensuring they are bad or just replace them for the hell of it?!
Old Aug 3, 2001 | 03:38 PM
ede's Avatar
ede
allen you dumbass this is so far over your head you'll never figure it out let alone fix it. i'd look at u joints first if it were mine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 3, 2001 | 10:59 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Thanks, ********, I think I will!
I had a funny feeling the post you'd reply with would begin with "allan you dumbass" so here ya go! LOL!
I admit, I know **** about rear ends, my wife knows a lot about mine tho!
Those darn Borg-Warner rears are too good to break!
Old Aug 4, 2001 | 04:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do you have discs or drums in the back?
Old Aug 4, 2001 | 09:33 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
Do you have discs or drums in the back?</font>
Disc
Old Aug 5, 2001 | 11:48 AM
82z's Avatar
82z
I'm thinking bad carrier bearings.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
TexasMaro
Sep 15, 2015 06:50 PM
Randomtask2
Sep 7, 2015 05:06 PM
