Tranny fluid change - synthetic?
Old Aug 7, 2001 | 03:01 PM
Boham92RS's Avatar
I am going to be changing my rear diff fluid, and I purchased 2 quarts of Mobil 1 synthetic fluid. The rear is 3.42 posi. Should I also add the GM posi additive? The additive says it should only be used w/ convential oils, and Ive read that it is not needed with synthetics. Any help would be great!
Thanks...
Old Aug 7, 2001 | 03:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's definitely needed with synthetics. Put it in first, then fill it up with gear lube.
ICON Motorsports
Old Aug 7, 2001 | 05:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Your brush is too broad. It is not needed with AMSOIL Series 2000 75W90.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 7, 2001 | 05:29 PM
Boham92RS's Avatar
Ok, thanks.. I have the Mobil 1 already, so I'll put it in.
Old Aug 7, 2001 | 05:49 PM
BOTTLEDZ28's Avatar
Transmission: A4
I used mobil one sythentic gear oil in the rear of my z28 and noticed it would make weird clunking noises if i turned sharp at a low speed. This was due to not having any additive in it. i ended up changing the oil again and using the GM stuff and it worked perfect
Old Aug 7, 2001 | 10:15 PM
breathment's Avatar
i have a limited slip, i added mobil 1 synthetic, with NO additive, no noise or problem at all. but thats just my situation.
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 8, 2001 | 06:26 AM
Pro Built Automatics's Avatar
Always add the additive!! It will not do any harm!
Old Aug 8, 2001 | 03:24 PM
u r sofa king we tah did's Avatar
ive been running for 30k with mobil 1 with no additive and have had no problems what so ever
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
