Berlinetta to firebird axle swap? Work or not?
Old May 1, 2009 | 11:05 AM
Chase_Newton's Avatar
Hey, i'm swapping out an axle from a rearend of a berlinetta to put into a firebird, will this work? or am i out of luck with these parts?
I own a 1984 Pontiac Firebird 2.8L V6, just wondering what parts (if any) would be compatible from a berlinetta.
Old May 1, 2009 | 11:24 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Berlinetta to firebird axle swap? Work or not?
yup...all third and fourth gen rears are direct swaps with eachother.
Old May 1, 2009 | 11:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. If you're talking about the rear end, yes, the swap is direct. The axles themselves are also a direct swap. Check the FAQ on 10-bolts at the top of the page for further info on what you may need to effect a swap.
JamesC
Old May 1, 2009 | 11:58 AM
big gear head's Avatar
Axles are not always a direct swap. There are 26 and 28 spline axles. Be sure that both are the same.
Old May 1, 2009 | 12:17 PM
Hmmm i see, i'll have to look into it. Thanks
Old May 1, 2009 | 12:47 PM
subroc's Avatar
Engine: 355 TPI
the year change was around 89/90. After that was 28 spline 10 bolts, and before was 26 spline. And lets not even touch on 9 bolt rear ends lol. If your swapping entire rear ends and not just axles then it wont matter. If your swapping just the axles then it will.
Old May 1, 2009 | 12:53 PM
Yeeeeeeeeep, i'm swapping just the axle if possible... lol
Old May 1, 2009 | 12:57 PM
JamesC's Avatar
The Berly / Bird should be a direct swap of 26-spline axles; however, taking a peek before you dive in is always a good idea.
JamesC
Old May 1, 2009 | 03:04 PM
Would an 82 Berlinetta Camaro V6 axle fit an 84 Firebird V6 rear-end?
Old May 1, 2009 | 03:21 PM
JamesC's Avatar
If both rear ends are what you say they are, yes, as both would be 26-spline axles.
JamesC
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
draco
Oct 4, 2015 09:25 PM
jharrison5
Aug 19, 2015 05:53 PM
