constant pressure valve body?
Old May 9, 2009 | 08:03 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My 86 IROC when the tv cable is not connected, has long drawn out shifts, and shifts hard. I thought when the tv is not connected, the gears will stack and shift too fast. I am thinking I have a valve body w/ constant pressure. Can this be confermed w/o taking the pan off and checking??
Old May 12, 2009 | 11:26 PM
Pro Built Automatics's Avatar
Re: constant pressure valve body?
This is normal for a stock GM transmission without a valve body kit. It just kept you from "wasting" your transmssion. Put the TV cable back and adjust it correctly.
Old May 13, 2009 | 10:23 AM
I did connect it back right away. I was told or I read that when it is not connected, it will shift fast, and early, and "stack" when it is not connected. Is there any thing to what I was told?
Old May 13, 2009 | 12:34 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The TV
Old May 13, 2009 | 12:35 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The TV is more than just shift timing, it is also line pressure. You must never drive without it, even half throttle without the pressure rise can kill a 700. I've done it.
Old May 13, 2009 | 06:05 PM
Thankyou atilla. I know the tv cable controls pressure and it's bad to not have it hooked up. I unknowingly drove it over 80 miles w/ it not connected, and it didn't ruin the tranny. Usually that kind of luck doesn't come my way. Anyway I took it to a tranny rebuilder, and he gave it a clean bill of health. I was amazed it didn't blow and so was the mechanic. But fact is it went that far and didn't burn the tranny. By the way, I bought the car that way not knowing the tv cable was unhooked.
Old May 13, 2009 | 07:50 PM
jonarotz's Avatar
Car: 91 Z28
Pro Built is right, it will live with the cable completely unhooked. There is actually a big checkball that allows high line pressure to save itself. However if the cable is misadjusted/too loose it will shift soft and quickly and burn itself up.
Old May 13, 2009 | 08:27 PM
that's interesting. I thought if the cable was unhooked, it would stack.. shift way too soon, but I learned something. I about had a kitten when I found out it was unhooked. It is shifting fine now, the fluid remained pink and unburnt, and I was relieved when I found out it is still ok. What if the line pressure is too high? Or is there such a thing as too high?
Old May 13, 2009 | 08:45 PM
jonarotz's Avatar
Car: 91 Z28
If the pressure is high you will have hard shifts. High pressure just makes the pump work harder.
Old May 13, 2009 | 08:56 PM
is making the pump work harder bad?
Old May 14, 2009 | 02:23 AM
High line pressure is always hard on pumps, especially at lower rpm's.
Old May 14, 2009 | 09:11 PM
Hey Pro Built, I was reading about constant pressure valve bodies that keep 200 psi regardless of the tv cable hook up. Would this be hard on the pump? is 200 psi at low revs too much on the pump??
Old May 25, 2009 | 04:46 PM
I do not use them, or recommend them. When the TV cable is set right, and the right things done to the valve body/pump, there is no better way.
Old Aug 9, 2009 | 08:24 PM
I know this thread is old, but would a constant pressure valve body be hard on the tranny pump? If not why do you not recommend them?
Old Aug 10, 2009 | 05:04 AM
The pump is not designed to handle high pressure at low rpm's and all of the time. They wear at a very high rate when at high line pressure all of the time. It is also very hard on the sealing rings, splines, and everything else in the gear train. That is one reason I do not recommend them. Dana
Old Aug 10, 2009 | 10:04 AM
performabuilt's Avatar
I would concur with Dana on the constant presure valve body. I think they are a bad idea.
Old Aug 10, 2009 | 10:18 AM
I'm sure your reasons are good, but what is wrong with constant pressure valve body?
I am editing this post. I forgot to read probuilt's statement. I'll pass on the constant pressure valve body. Thanks for the advise..
Old Aug 12, 2009 | 02:01 PM
fljerry's Avatar
Car: 1984 Camaro
Engine: 5.0 Liter (305 ci)
Transmission: 700R4 Automatic
I have an additional question on the TV cable hook up. I purchased an 84 Z28 which was in a pile of parts in a guys garage. I had the 700R4 transmission rebuilt as well as the 305 engine. The car came with an Edelbrock 1406 carb. I cannot figure out where the TV cable hooks up to the carb, or the cruise for that matter. A picture would be great. Looking at the Edelbrock website (vidoes) linked somewhere on here also talked about a vacuum line from the carb to the transmission. The line the Edelbrock spokeman talked about was plugged when I got the car. Sorry this is so long but could use some help as I get ready to start this girl up.
Old Aug 12, 2009 | 06:09 PM
It sounds like your carb was not set up for tv linkage. I had a similar issue with my carb. It had no linkage to hook the tv cable to, so I made my own. I had to make sure the geometry was just right. It works well now. I wish I had the dot com sight, but I don't. Just google 700r4 tv linkage, and you will find an abundant amount of info.
Old Aug 12, 2009 | 06:29 PM
fljerry's Avatar
Car: 1984 Camaro
Stev, thanks I found a couple links by searching TV cable on this site. Any help on the cruise set up or vacuum line?
Old Aug 12, 2009 | 06:45 PM
If you mean vacuum line to the tranny, I don't believe there is one. I don't know about cruise. I never had to deal with it. My cruise on the IROC flew south anyway. I am still used to cars with out cruise. Back in the 60's and early 70's, only personal luxury cars had it..
Old Aug 12, 2009 | 06:48 PM
fljerry's Avatar
Car: 1984 Camaro
The first car I ever special ordered was a 1984 Berlinetta. It was loaded, including cruise. I do a lot of driving so cruise is nice.
jklein337
Sep 19, 2018 06:23 PM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
