gears?
Old Aug 23, 2001 | 01:27 AM
1989camarorsrs's Avatar
gears?
i dont realy know much about gears but i wanna get either 3.42s or 3.73s i got 2.73s right now but im confused about the 3 series or 2 series carrier thing what do i need to get before i bring it to a shop to get installed i knwo the gears and pinion and berings is that it help needed thanx
Old Aug 23, 2001 | 06:00 AM
custman87T/A's Avatar
You have a 2 series carrier. If it is a 10 bolt (look at the cover and count the bolts) there are companies that make as high as 3.42 for it. You neeed a 3 series carrier for 3.73 gears. If you have a 9 bolt it is very expensive to do gears in it and from what I understand not many places sell them.
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old Aug 23, 2001 | 07:39 AM
82camaro's Avatar
Car: 82 camaro SC
You can get 3.73's in a 2 series.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 23, 2001 | 10:04 AM
im looking in the summit magazine for the gears right now but i dunno which 10bolt gears i have i have an 89 rs there are 8.2dia, 7.5dia, and 8.5 diam oh and there are 2 groups of 8.2 one with pinion stem and other with 25 spline pinion if anyone has a summit magazine they can see what i mean thanx
Old Aug 23, 2001 | 12:12 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
you want the ones listed for the 7.5 inch 10 bolt with a 2 series carrier
Eric
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Moderator at: www.generation-3.com
Old Aug 23, 2001 | 02:22 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I believe an 89 could have either a 10 bolt with a 7.5 or a 7.625 ring gear or it could have 9 bolt.
I can get you all the 9 bolt parts you need, including gear sets to 4.10.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Old Aug 23, 2001 | 04:27 PM
im pretty sure its a 10 bolt in summit i would need the one thats RMG-4900071?? its the 3.73 gear (3.08 lower carrier )
Old Aug 23, 2001 | 06:20 PM
82camaro's Avatar
Car: 82 camaro SC
If you have 2.73's it's a 10 bolt 2 series carrier. Correct, RMG-4900071, it's the same that I have.
82camaro
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
