700r4 without ECM
Old Aug 23, 2001 | 10:08 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
700r4 without ECM
Can the '84 700r4 tranny run just fine without the ecm. Thanx.
1984 Trans Am Coupe
700-R4 Tranny
Mods:
K&N, Rebuilt carb, Rebuilt heads, 3" Mandrel Exhaust, Hooker Headers, Crane Cam, 1" Lowering Springs, Carion CD, Kicker Speakers, 2 MTX 4000, Pearl White Paint
"Live It To The Last"
Old Aug 24, 2001 | 05:22 AM
transfixleo's Avatar
All except for lock up. You should have a valve in the VB for it and a simple trick is to put a 5/16 checkball in the snout of the solenoid to block it on. Now the valve will turn it on and off. THis assumes that it is the original trans Make sure that there are four larger aluminum valves in a row (they will have SMALL numbers on them). If you see one that is SMOOTH and indented, forget it, it is a dummy plug and this won't work for you.
Just so people don't run out and try this, this will ONLY work IF you HAVE a shift valvetrain for L/U. PLUS, it won't exactly have ideal shift timing but being an '84, it didn't anyhow. It just may be too early for your likes on this one. A full TransGo Shift Kit comes with all of the calibration corrections you will need but you asked if it would work and that is what I told you.
Elephantismo
Feb 13, 2019 12:51 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
