700R4 2-3 shift issue
Old May 18, 2009 | 08:19 AM
f7firecat's Avatar
Car: Camaro
Engine: LB9
1987 Camaro, retrofitted 1992 LB9, 700R4. Recently replaced the transmission with a rebuilt 700R4 from a good shop. I did this to correct the wide open shift issue that I was having. Under WOT the transmission would not shift from 2-3, either manually or leaving the shifter in the Drive or overdrive under WOT, I would need to back off WOT just a little and it will shift fine. I am pretty frustrated right now. Second guessing my purchase, maybe I should have replaced this with a 400?
What area should I start to investigate, as now I have two transmissions that both seem to have the 2-3 WOT shift issue.
Thanks to all that reply.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
