Speedometer
Old Sep 20, 2001 | 04:37 PM
89bird350350's Avatar
Speedometer
I have an 89 firebird. It used to have a 2.8 in it but I blew it so I put a 350 in it out of an older camaro, I also bought a 86 firebird that had a 305 in it and used all the accesories (alternator water pump etc..) from it with the serpentine system. I pulled the computer from the 86, but most the stuff in the car doesn't run from the computer now anyway. I pulled the 700r4 from the 86 also. I have finally managed to get it all working, short of needing an exhaust from the Y-pipe back (which I plan on getting next month) except for one vital part.
The Speedometer. I can't get it to work, I don't know where to start. I have no idea what to do to get it working, there are only wires running from the tranny to the computer, no speedo cables.
Is there anything I can do to get the speedo working??
Jeremy Malloy
Old Sep 22, 2001 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What happened to the speedo wires that were in the 2.8 tranny? If it was a 700R4 too it should plug right in. You'll also need the correct speedo gears for your rear end.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
