"clunk" sound when sifting
Old Oct 1, 2001 | 12:17 PM
92Camaro305TBI's Avatar
I meant SHIFTING
Started after I had the tranny rebuilt and haven't had time to take it back yet..
J/W When the auto shifts from 1st to 2nd and then from 2nd to 3rd I and feel a clunk noise fromt he back..
It is most noticable from a stop and accelerating mildly. Not WOT or slowly moving in rush hour traffic.
Any idea.. or could you give me something to look out for?
For some reason I don't think its the mount...?
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index...ew&rideid=6100
[This message has been edited by 92Camaro305TBI (edited October 01, 2001).]
Old Oct 1, 2001 | 01:25 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
How many miles are on the car? Or more importantly, the rear axle?
This is not likely but I have seen it happen. You could have so much excessive play in the ring and pinion that the quick and harsh shifting of a freshly rebuilt transmission could cause some noise. Of course, a toasted pinion bearing or side bearing could cause some noises in the rear end as well.
Check all of the bolts that hold the rear axle in as well. Like the LCA bolts, Panhard Rod bolts, and shock bolts. If any of those are loose they could make noise.
A toasted U-joint can also make some noise.....
Basically you just have to get under there and check everything out until you find the problem.
A little more info on how the noise sounds might help us help you........ (ie clank, thud, metal on metal, etc...)
Good Luck
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 1, 2001 | 02:28 PM
Thanks.. As soon as I get off work Ill see if I can get under and look.
I have 110000 and it was at 106000 when I had it rebulit....
More of a thud than a clank.. its a dull one way thud.... when the rps drop at the shifting point thats when you hear and feel it.
Old Oct 2, 2001 | 02:13 AM
Jono's Avatar
I just had that problem fixed, it was the tranny mount that snapped in half. Not very expensive to fix
Old Oct 2, 2001 | 08:29 AM
crucial's Avatar
I hope you had them use a polyurethane model or it WILL break again! Hehe
1991 Z28
357 4 bolt main block, TrickFlow 23 degree heads, Harland Sharp roller rockers, Accell base, SLP siamesed runners, 52MM Throttle Body, MSD6A ignition, Home made ramair system, 2500 stall + race built transmission etc
Old Oct 2, 2001 | 01:31 PM
theres a transmission mount in the rear of the car?
Old Oct 2, 2001 | 01:40 PM
Matt87GTA's Avatar
No. He didn't read your post close enough or he is not very smart. If the mount was the problem it would be even worse under heavy load (WOT). Have you gotten under the car and checked for loose mounting bolts and/or U-joints?
EDIT: And there is only one trans mount on the car. It is more towards the middle-to-front of the car, not the rear. Did you have the trans done or did you do it yourself? If a shop did it, they likely would have replaced the mount when the trans was rebuilt if it was in bad shape.
1987 GTA L98 MD8
My GTA
[This message has been edited by Matt87GTA (edited October 02, 2001).]
Old Oct 2, 2001 | 02:33 PM
I had a shop do it and I think they did replace the mount..
I tried to get under there last night, But unfortunatly I couldn't fit and didnt have the jack to raise it up... Ill get jacks and then play with what ever I can to notice anything loose...
thanks for the help... Just to make sure.. Im looking in front of or around the rear axel right...
thanks again
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
