torque converter lock up problems
Old Jun 18, 2009 | 08:49 PM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
I have an '89 fibird formula with a 350 tuned port motor and a stock 700 r4 does anybody know how or what I have do to disconnect the lockup feature on my torque converter. I've been having issues where the car dies from idle when shifted into gear and dies on deceleration when coming to a stop if left in gear. If I pop it into nuetral it stays running,and I have have to feather the throttle before shifting back into gear or it dies. Can anybody help??
Old Jun 22, 2009 | 09:05 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
Re: torque converter lock up problems
I have the same problem. It's mechanical. You have to change the torque converter. It's locked up. My car's at my buddy's shop, and he checked the solenoid, and the oil pump. They are working fine. I have to get a new converter.
If your solenoid was faulty the car wouldn't change gears. I was told that by another transmission guy.
Hope this helps!
Old Jun 23, 2009 | 12:58 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
its a four wire plug above the shifter cable on the left side of the transmission just unplug it.and the transmission will shift with the lockup unpluged.
Old Sep 5, 2010 | 05:35 PM
kylemeadus's Avatar
Car: 25th Anniversary Convertible Z28
Axle/Gears: Stock
i have the same issue. i swaped trannys and now it dies when i put it in any gear wheither i give it gas or not. its as if the coil loses power. ive also tried it without the lock up wire plug and it does the same thing. any ideas?
Old Sep 5, 2010 | 05:53 PM
Pro Built Automatics's Avatar
"If your solenoid was faulty the car wouldn't change gears." This is wrong. The transmission will still shift, and probably shift very hard. Get another torque converter, as the clutch in it has locked itself up. DO NOT try and feather the throttle to get it to move. YOU WILL ruin the forward clutch and/or the low reverse clutch in short order. Then the transmission will have to be removed to fix this.
Old Sep 9, 2010 | 02:23 PM
kylemeadus's Avatar
Axle/Gears: Stock
with the car on jack stands it souldnd matter if the tourque converter was locked up or not, no? the car souldnt die i would think. it even dies when i shift to nutrual. im lost
Old Jan 14, 2011 | 03:45 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
i'm having the same exact problem!!!! my cars driveable but i do have to be mindful of my deceleration as well as sitting at an idle while in drive, and when i look under my car the TC is always spinning or engaged i noticed after i did the swap about a month or 2 ago when the car was still on jackstnds the tires would spin while the car was in nuetral i thought it was weird but i didnt care i got my care back. but now it wants to stall a lot when im in D at idle i have my old TC so i guess im gonna put that in and see if it fixes the problem
Old Mar 12, 2014 | 12:18 PM
ezrsss92camaro's Avatar
did it help?????I just bought a 92 rs Camaro with a 305 tbi,, I had one of these years ago ,and had it for 11 years.. never had any of these issues??? We put my car up on a friends lift and discovered some had unplugged the lock up solenoid on the transmission. drivers side ???my friend thought it looked like the trans was re[placed..he thought maybe they had some kind of shift kit in it? other than the color of the car my last one was the same and it drove great, this one drives like a raped ape.. lights up the tires at will???not that im complaining about the performance side just trying to figure out why??? Transmission seems to shift fine and It down shifts fine..i do notice it winds out a bit sometimes when on it heavy to pull out onto the bypass?? but she takes off..just feels really different???any ideas????
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
