TH-350 to 700R4 Swap??
Car: 1992 Camaro
Engine: 350 miniram
I bought my Iroc equipped with a TH-350, and I just got a 1991 700R4 yesterday that I am going to be swapping in. Along with the TH-350 the car also came equipped with a non computer controlled carb. setup as well. With that said I have a few questions.
I see under the car a 4 prong connector, even though there are only 3 wires going into it. Is this what controls lockup on the 700R4? The guy I bought the car from left the computer under the dash and some of the other wires the car came originally equipped with, so even though the engine isn't being run off the computer, if I hooked up the connector to the trans, would the computer still work the lockup on the trans?
Next, there is a 2 prong connector on my trans as well, is this for the electronic VSS?
What is that tube coming off the top of the trans? Is this some kind of vent? There is only about 4in. of hose coming out of the trans. is this enough or do I need to add length?
Last, What do I need to torque the flexplate to engine bolts to?
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by david auster:
Thanks</font>
Thanks</font>
yes, the 2 prong is for the electronic speedometer instead of the cable operated that you have now. you should be able to switch the two around. yes, it is a vent for the trans. no need to add any more length to it. don't know the torque for the bolts always just tightened them as tight as i could get them.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Long tail shaft th350's are 9". The 6" is a short tail shaft.
Long tail shaft th350's use the same driveshaft as 700R4's. Short tail shaft th350's use the same driveshaft as the 82-83 f-body with the 200c tranny.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
C409
09-01-2015 03:42 PM
Eric-86sc
08-24-2015 09:01 PM
