Transmission Tailshaft Seal - Leaking
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Mine seems to be leaking (about 2 dime sizes ever week). Are they hard to replace? Do i need to drop the tranny to do it? Should i replace the seal or the bearing too? Do i need any special tools to do the job?
Any help would be appreciated.
Car: 1988 Iroc
Engine: 5.7L
Re: Transmission Tailshaft Seal - Leaking
Anyone? can i just for the time being put a small bead of silicone around the tailshaft to prevent it from leaking?
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
pull the drive shaft, take an 13mm- 15mm open end wrench and get part of the wrench behind the seal, pop it out. use a big socket the size of the new seal and hammer it in lightly till its seated properly.
Car: 1988 Iroc
Engine: 5.7L
Sweet, seems pretty easy. I take it i will have to drain the fluid first?
put a drip pan down, very little fluid will leak out.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Be sure to put a little oil on the driveshaft yoke so your new seal is lubricated on start-up.
Car: 1988 Iroc
Engine: 5.7L
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
This is the one I used, and the part number is there. I'm sure there are plenty of other names for it, but this is all you have to search for. http://www.autozone.com/autozone/par...0_3498%2C10492
someone972
Aug 30, 2015 12:52 AM
