regular ATF vs Trick Shift
Old Oct 28, 2001 | 09:33 PM
Faithbird88's Avatar
i just finished my Clucth and replaced my lost tranny fluid during the process, and i just filled it with Trick shift, now my tranny requires ATF is trick Shift Safe to use, it says on the bottle works just like regular fluid only with a bit more kick..anybody have suggestion, or past experince of what to do or not to do?
Thanks mike
Old Oct 29, 2001 | 12:17 PM
89FormulaL98's Avatar
for some reason my car could cherp the tires going into second w/ regular fluid, but not w/ trick shift... go figure
Old Oct 29, 2001 | 01:00 PM
CODY BEHNKE's Avatar
I was told by a very reputible transmission shp here in town that you shouldnt use it in 700r4 transmissions. It's to thin and causes slippage because it goe through the pump to fast to buid up enough pressure.
Old Oct 30, 2001 | 01:40 AM
Pro Built Automatics's Avatar
It is Ford type "F", do not use it in any 700R4 under any circumstances. Look at past posts from me or transfixleo.
Old Oct 30, 2001 | 02:00 AM
craiger's Avatar
Pro Built, What do you think about amsoil transmission oil?
Old Oct 30, 2001 | 11:17 AM
According to the tech people who analyze oil, the #1 oil is Amsoil, #2 is Redline. B&M, Royal Purple and others are at the bottom of the list.
Old Nov 3, 2001 | 06:19 PM
hawaiianguy's Avatar
I have been told by the local AMSOIL Dealer/Distributor that unless I can totally flush the transmission of all dextron atf, including what is in the convertor, that I should not use the amsoil atf because it will not mix with the dextron and will cause problems. I have also been told the same thing by some of the guys I race with.
Old Nov 3, 2001 | 08:37 PM
transfixleo's Avatar
I have not had any problems mixing Synthetic and regular ATF. Remember, he is trying to sell you expensive fluid and the more he selld=s of it the more he makes. Remember, I'm from New York so naturally I am cynical!
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Marc Brown
Sep 28, 2015 01:40 PM
RS Reaper
Sep 27, 2015 07:04 PM
