87 th700 into 92 RS? Please help
Old Nov 5, 2001 | 10:08 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Hi guys, I just need someone to help me figure out what I need to swap in a tranny from an 87 IROC th700. My car is a 92 RS th700. My problem is with the tailshaft on the new trans, it has 27 splines on it, does the driveshaft yoke that I will be reusing from my 92 also have 27 splines? Another thing I noticed is that there are actually two different size input shafts in the front of the trans. The bigger one has 30 spline, and the smaller one has 27 spline. Which one determines the torque convertor??? I just want to know all my facts so there are no surprises when I change them. Thanks alot
Jet stage II chip for 305TBI, march under drive pulleys, fabricated "lefty" exhaust, futura challenger tires (police pursuit approved). I maintain the mechanics of my vehicle. I've either replaced or inspected everything. I am proud to say that I have the FACTORY stereo equipment, as anything else as far as I am concerned is stupid and is is a waste of precious voltage. To my knowledge, aftermarket stereo's, speakers, sub-woofers, and amplifiers will NOT make your car faster.
Old Nov 5, 2001 | 03:43 PM
And also, my car uses an electronic speedo sensor, were they electronic or mechanical cable driven in 1987? If the 87 one is cable operated, can I just switch my electric one into the 87? If I had the trans in front of me I wouldn't be asking this question, but it's 50 miles away. Thanks again
Old Nov 5, 2001 | 05:48 PM
transfixleo's Avatar
The trannies will be essentially the same, including front and rear yokes. You will need to swap the metal reluctor if you have a plastic speedo (or vice-versa).
Old Nov 7, 2001 | 07:51 AM
Ok, here's the scoop from GM. They say that their replacement transmission for an 87 camaro is the same # listed for my 92. But they also said that an electric trans was not an option that year when I asked them about my electric speedo. So I'm asking you guys again- I KNOW my 92 has an electronic device that has the driven gear for the speedo on one end and a wire harness on the other. This part costs $106 from GM. Will I be able to install it into the 87 trans which IS cable driven? Is this the reluctor you were talking about TRANSFIXLEO? Thanks again for all the help
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
GTAsweden
Jan 20, 2007 01:00 PM
PerthZ28
Dec 31, 2006 11:29 AM
macone
Jul 23, 2002 10:20 PM
91B2L
Jan 20, 2002 08:11 AM
