How did yall hook up the torque arm without the bracket on the tail shaft?
Old Nov 7, 2001 | 11:52 PM
sslee's Avatar
I am taking out the 200 3 speed and installing a turbo 350, but it dosent have the bracket on the tail shaft.
What about the torque arm now?
82z28 (currently building)
70.5 camaro
383 with D-2 procharger
best time 9.38@148
Old Nov 8, 2001 | 12:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
B&M's P/N 30299 is a kit that includes a transmission mount and torque arm adapter that lets you use the stock torque arm.
A more expensive alternative is to use something like a Spohn torque arm and crossmember that doesn't bolt to the tailhousing.
Old Nov 10, 2001 | 05:42 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hey im doin a th200 to 350 swap...what is the problem with the torque arm ?
can i skip this problem ..without buying a kit ?
waht is the main problem ..please help
Old Nov 10, 2001 | 05:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The TH350 has no provision for mounting the torque arm bracket. There is no way to "skip" this problem. You either need to buy or fabricate some sort of bracket, replace the torque arm with an aftermarket one that doesn't mount to the transmission, or eliminate the torque arm entirely by converting to a ladder bar or other rear suspension setup. Buying the bracket kit is the simplest and least expensive way.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
deracer
Apr 11, 2016 12:04 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
