questions about setup
Old Aug 15, 2009 | 08:44 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
So at the end of this year once I start making money again I am planning on doing a build for my drive train. I have a freshly rebuilt 350 with a erson cam, headers, and full exhaust
I have a 700R4 and I want to leave it as such, but I am going to buy one and rebuild it and then take out the old and replace it with this one.
I am going to use this as a rebuild kit
http://www.summitracing.com/parts/BMM-70233/(and a B&M shift kit)
and I am going to get this torque converter
http://www.summitracing.com/parts/BMM-70419/
This shifter
http://www.summitracing.com/parts/BMM-80694/
Now I am debating putting a transmission cooler on it, I know just regularly driving my car around it seems to get pretty warm in the tunnel so ill have to ask advice on that.
I also want to put a rear in the car, I have an open dif right now( I believe I mean one tire fire so ya know, but I really need to get under it and see if I cant get the tag) But I would like to get a LSD, so what rear should I use? I want to use my car as street/strip so I want it to have a good 1/4 ratio. so any ides?
So I think along with some other parts that I have to account for ( I want to get a bushing set for the rear) that break/need replacing. How does it sound? I dont think it will be to hard to rebuild my own transmission
Old Aug 16, 2009 | 05:03 AM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: questions about setup
If your car is a 85 this shifter i believe is not the one. if you look at the application it only goes up to a 81. I just ordered the 80692
Old Aug 16, 2009 | 03:53 PM
Pro Built Automatics's Avatar
There are much better rebuild kits and torque converters for about 50% more. They will do much more, and you won't be paying for just the name. B&M track is very poor, do a little research on this to prove it to yourself. Dana
Old Aug 16, 2009 | 10:44 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
News to me, I dont really know that much about the drivetrain companys I've never messed with them I just knew that B&M was good(or heard)
What would you recommend?
Old Aug 18, 2009 | 02:26 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
i just got that b&m in the mail will install this weekend (looks like fun.) wont be able to drive it quite yet but ill let you know how it feels.
Terrell351
Jun 13, 2021 01:13 PM
beastin91rs
Oct 9, 2015 07:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
squiggy2
Aug 9, 2015 09:30 PM
