I got the "7.5 inch 10 Bolt blues!"
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Well, I changed my oil, swapped out the new Pro Systems carb, and mounted up some new Mickey Thompsons.
Take the car out for a little cruise. I get about 5 miles out and decided to hit it. The car hooked hard and pulled like a train. The I hear it! The loudest knocking I have ever heard from a car. Limp it back to the house and scrath my head for a while. Could only be trans, driveshaft or rear? The Flexplate and Torque converter are spinning fine.
Pull the rear cover and bam! rounded out ring gear and a pile of teeth!
This rear had Moser axles, long studs, Moroso alluminum cover, aftermarket 4.10's and Auburn carrier.
Think I should repair or replace?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: I got the "7.5 inch 10 Bolt blues!"
repair would be the fast cheap way, but it will happen again. If the buget allows, maybe think about upgrading
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
9" time...never have to worry about it again...well...as fast as you are going currently. even with some spray you should be good on it. i love my moser 9" unit.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Man, i'm one of the lucky few that never had a problem with a 10 bolt. full nitrous launches in the 1.4x 60's and it held, bone stock rear end out of a 4th gen.
Cant wait to try it out with the turbo motor
fix it with another stocker for a cheap quick fix but definately need a new rear end.
Keep the ring/pinion to a 3.42 or maybe 3.73 and it will last longer. Less teeth on those gears so the teeth are actually thicker/stronger
Car: 1986 Camaro SC
Engine: None
Transmission: None
Damn if I didn't just buy a brand new open car trailer for $2500. I would have had Moser make me up a killer 9 inch.
The funny thing is...I was the guy saying " Look how fast i'm going on a stock rear!" Who needs a 9 inch.....
I'm gonna have to patch it up for the season and save over the winter. God doesn't want me to have that new nitrous kit! Or maybe it's the wife,
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yep, swap it out for a stocker to keep it going and or save for a 12 bolt/9inch/60 of your choice. I for my Moser 12 bolt used for 150$, but i know i will never need to but a rearend again for my car.
Taller gears(numerically lower) have larger pinions gears, and thus more teeth on the pinion. More teeth = more contact area between the ring and pinion. I have said for a long time that the 7.5" 10-bolt will do quite well as long as you don't go lower(numerically higher) than a 3.73. Past that they become unstable really quickly.
Personally, I'd go 12-bolt or S60. 9" eats more power for nothing.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I hate to hear the news. I know you can taste 10's with the new carb and tires.
In your case, I would just pick up a 10-bolt and salvage what parts you can.
Car: 1986 Camaro SC
Engine: None
Transmission: None
You know it. I guess i'll hold off on the 4800 stall also because if it can't hold the 10 incher. I know i'm in trouble with the 8"
On Probation
Engine: several
Transmission: none
Axle/Gears: none
9" housing, with a Strange aluminum centersection that takes GM 12-bolt car gear sets. The best of all worlds. if you do that, you can go 33 spline.
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
just replace your stocker for now and save for a 12 bolt or S60. S60 gets my vote though.
Engine: 7.0L
moser 12 bolt would be my last choice. they don't use through bolts on the torque arm. if you want a 12 bolt, do a Strange unit, if you want a 9", moser all the way.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
