Fixing a transmission problem
Old Nov 26, 2001 | 08:07 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I think my transmission pressure regulator needs replaced. It makes a whining sound while idling and even louder when in reverse.
I'm not sure exactly what this devise does. What is the purpose of this regulator? What sort of problems will a bad regulator cause? How easy is it to replace one? What is the cost of a replacement?
I know their was a recall on these back in the day, but I'm not sure if mine is actually bad. If possable could you guys tell me some of the signs to look for?
Mark
Old Nov 27, 2001 | 04:45 AM
transfixleo's Avatar
Most likely your filter is restricted. You will need to correct why this is but you could for the time being replace the filter and fluid, just don't expect the problem to be truely cured.
Old Nov 27, 2001 | 09:03 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Yes but is their any way to tell when your pressure regulator needs replaced?? What function does the pressure regulator serve?
Old Nov 27, 2001 | 03:23 PM
The PR Valve works in conjunction with a whole bunch of other valves to keep a certain (variable) pressure in the tranny. Ironically this is not really a part that goes bad. To monitor the PR System you need a quality (Snap-On) pressure gauge.
Old Nov 28, 2001 | 09:38 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I just had my tranny serviced not to long ago so I don't see a restricted filter being the problem.
Old Nov 29, 2001 | 04:20 AM
That is unless something is generating particles that are again filling up the filter. I see this all the time, especially when the converter is going away.
Old Nov 29, 2001 | 05:43 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by transfixleo:
To monitor the PR System you need a quality (Snap-On) pressure gauge.</font>
So I should throw my Kent-Moore Gauge in the trash? Hehehee
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 29, 2001 | 02:54 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
how can you tell when your converter is going bad?
I just installed a new poly tranny mount so I'm able to fell vibrations a lot better now. when I'm driving just before it shifts into the next gear it starts to vibrate. Once it shifts to the next gear it feels smooth then when it goes for the next gear it starts to vibrate again and so on for each gear. Is this normal? Maybe it's something that I never noticed before due to the stock spongy rubber mount.
Mark
Old Nov 29, 2001 | 04:09 PM
I am sure the KM gauge is probably OK but I think you have seen/used the Mac/Matco/et al/ gauge. I have see way too many blow the heads off and if you happen to be holding it inside the car on a road test....
Actually since you probably do 4L80E's, I would strongly recommend the Snappy high pressure gauge that they sell. It reads between 0-500 but has a 'cushion' that runs up to 1500 PSI which is great if you are checking out a 4L80E that has a high pressure/breaking parts problem. 600-700 PSI on a 300-400 PSI gauge can be downright dangerous when the gauge is in your hand.
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
86IROC112
Apr 9, 2016 10:20 PM
dyeager535
Aug 28, 2015 08:10 AM
