700r4 Trans. isn't shifting up ???????
Old Dec 2, 2001 | 09:03 AM
JDIroc's Avatar
Okay i pull out of my friends driveway and i had it in drive and it stayed in first gear, and after a couple of feet it felt like the trans. was in nuetral. then it hit second gear at 3500 rpm????? and i milked the car the rest of the way home when after a mile it finally fell into third but no overdrive.?? The night before not the slighest of a problem, and i wasn't beating on it. I just put a B&M street strip shift kit in about 3,000 miles ago. I run mobil one sythetic in the trans and the motor. I have already checked the trans. fluid is only a tad low. PLEASE HELP THANKS JUSTIN
88' Iroc-Z 350 TPI
36,000 orig. miles
Ported/polished heads
Milled heads 10 thousands
MSD 8mm Wires
Random Technology CatBack
TPIS adj. fuel pressure regulator
TPIS Airfoil
B&M Shift Kit
Gutted Cat
3.27 posi
Best run stock=14.344 95.78 mph
Old Dec 2, 2001 | 09:22 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Sounds like a broken 2-4 band. Time for tranny to come out and re-build.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Dec 2, 2001 | 11:33 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, something sounds funny w/ the band. Do you have reverse? I've never seen a busted reaction shell in a tranny that was built prior to '96, Don't know if its a design change, or just from working at a new car dealer, but if it is busted, you'll loose reverse also.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 12:24 PM
JDIroc's Avatar
I have reverse i have neutral and drive, they all regester into what selected gear but when in overdrive or drive it won't shift to second gear until 3500rpm. I have a feeling a piece of debris is clogging something it's been like 2 months after i put the shift kit in and it has been flawless. Should i try and flush out the trans. first by running like 15 quarts through it? The only thing i can say is that night before i had to slow down fast and i downshifted from drive to second gear to help the car slow down. but that was it ???
Old Dec 2, 2001 | 01:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
My trick to determine a broken band is to measure servo cover travel. Most of the ones that I have seen broken will travel in excess of .250" (1/4") Spec is .064-.125"
This is done by mounting a dial indicator on the servo cover, then pushing it in as far as it will go.
Did you notice the problems immediatly after your forced 3-2 shift?
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 02, 2001).]
Old Dec 2, 2001 | 09:49 PM
jamesbern's Avatar
I had the same problem after my shift kit, the throttle valve was stuck in the valve body. Wouldn't upshift except under W.O.T. Check this before pulling the tranny.
Old Dec 3, 2001 | 02:41 PM
transfixleo's Avatar
Does it feel rougher when you put it ito gear? If so, you likely have a sticky throttle valve in the VB. The B&M NON-shift kit doesn't fix this. You could also have the TV cable not set right either. And yes you could have the not uncommon burned band/drum.
Old Dec 5, 2001 | 08:22 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
also check the cable to be sure it is not kinked, melted, or frayed. I had a 82 cadillac eldorado and the trans would not shift in any gear till very high rpm like 3500 to 4000 rpm very high for a diesel, then bang it shifted, it was intermintant and finally I shelled the torque converter, the insides went to shreads and it would not move, the tv cable was frayed and stuck in the full throttle position.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
LT1 intake soon...if I can find one!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
LT1 intake also if I can find one!!
Old Apr 13, 2010 | 11:18 PM
KARR81's Avatar
Car: 1983 Firebird Trans Am
Engine: 1969 Chevy 350 crossfire FI
Transmission: 700R4 overdrive auto
Axle/Gears: Posi Rear
Re: 700r4 Trans. isn't shifting up ???????
I have a similar problem when the tranny is cold. Once it warms up, the throttle valve doesnt seem to stick anymore. The shift to second however, once warmed up, is pretty forceful. I had AAMCO look at the tranny and put new fluid dexron IV in it last year. They said everything looked good. Now a year later my tranny starts this business. This car is not a daily driver and the fluid is still clean. I hope my 700r4 is ok.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
88rscamar0
Sep 23, 2015 09:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
