has anyone ever used a seperate inline tranny cooler?
Old Dec 9, 2001 | 09:42 PM
breathment's Avatar
I saw one online, and it seemed it would be ALOT easier to change the fluid AND the filter if u had a remote filter.
however, if i were to get one, would i just be able to remove the filter in the pan without having to do anything to it?
anyone have one?
http://www.bmracing.com/noflash/prod...ranFilter.html
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited December 09, 2001).]
Old Dec 10, 2001 | 09:30 PM
breathment's Avatar
that a no?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
Old Dec 10, 2001 | 10:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Im being tempted to run a screen filter in the tranny and run one of the inline up front some where. Haven found a good spot to put one on an fbody, yet.
SSC
Edit: I guess they were nice and told everybody it was a PH8A, there goes my nice little rant
[This message has been edited by SSC (edited December 10, 2001).]
Old Dec 13, 2001 | 05:12 PM
breathment's Avatar
top
Old Dec 14, 2001 | 08:11 PM
Ponchojoe's Avatar
I'm running a remote trans filter (the one from Summit) in front of my passenger side front wheel under where the air filter can sits. To reach it you have to remove the panel underneath at the air dam. Mine is tied to a B&M Supercooler that is located infront of the radiator.
1988 Formula 350, auto, 3:27 Loaded (1 of 2612)
Handcontrols
Old Dec 14, 2001 | 10:04 PM
breathment's Avatar
Do you have ur stock filter on too??
- David
Old Dec 18, 2001 | 09:46 AM
1985_glue_factory's Avatar
I have a B&M 24,000 GVWR trans cooler on my TH350. It is a LOT easier to change the fluid since it hooks up with rubber hose to the hard lines. All you have to do is get a clean container and fill it with a couple gallons of trans fluid, disconnect your suction sine and place it in the fluid. Disconnect your pressure line and put it in a drain bucket. Have a bud start the car in neutral while you are up front making SURE the suction line is emmersed in fluid, and when the pressure line starts squirting clean fluid, shut the car off, hook the lines up, and check your fluid. There ya go, shade-tree trans flush. Not anywhere NEAR as easy (or as good) as having a flush macnine, but way easier than dropping the pan.
Old Dec 18, 2001 | 04:14 PM
Ponchojoe's Avatar
Still running the stock filter in the tranny along with the remote filter and the cooler.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
lanceflame44
Sep 25, 2015 12:28 PM
