Driveshaft Question
Car: 1984 z28 h.o.
Transmission: 5 speed
Driveshaft Question
http://boston.craigslist.org/sob/pts/1387855005.html
I know this guy says it doesn't fit a camaro. I don't know what year car he tried to put it in, but I am not aware of many other rwd chevy aluminum driveshaft. Does anyone know if these measurements actually might be correct for a thirdgen? If so I was going to go check it out.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Driveshaft Question
The 1LE alum shaft is 41 1/2 U-center to U-center.
JamesC
JamesC
On Probation
Engine: several
Transmission: none
Axle/Gears: none
the camaro is too short for the driveshaft. You can get the driveshaft shortened, but then you're out more money. May as well just get a 4th gen driveshaft.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
by the way, if that driveshaft is more than 3.5" diameter, you'll never get it to clear the torque arm. 3.5" is really pushing it.
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Sounds like it would be out of a 1990s shortbed pickup truck. My brothers 2wd had a similar aluminium driveshft his was long bed though, i assume that the shortbed one is about that length.
Car: 1984 z28 h.o.
Thanks, I'm hoping to get one of the ls1 driveshafts as I have heard they are the best. I just do not know how to identify one unless it is in the car. I always feel like junkyards try to pull one over on you.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
search for fparts as a seller on ebay, they have some ls1 shafts listed at around $120 i think,
i got one from the classifieds here for $150 with new ujoints and balanced, worth every$
ambainb
Apr 25, 2016 09:21 PM
theshackle
Aug 23, 2015 03:49 PM
