posi borge warner 9 bolt
Old Oct 6, 2009 | 06:54 PM
gaskincrew's Avatar
just wondering how dependable is a factory posi 3.23 borge warner 9 bolt is, bought it and it has disc brakes and came with master cyl. and prop valve, "its a complete deal, caliper to rotor and em cable. all suspension arms, even full of fluid , hope its good, gave 200 bucks, maybe i will come out ok, putting it uder my 86 drum iroc. is there a known common problem with these? thought even if posi has problem, the rear disc should be a improvement
Old Oct 6, 2009 | 07:05 PM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: posi borge warner 9 bolt
3.23 isn't a 9 bolt ratio closest would be 3.27 the 9 bolt is a better rear than the 10 bolt but parts cost more than the 10 bolt.
Old Oct 6, 2009 | 07:11 PM
Stephen's Avatar
Car: 87 GTA
The 9-bolts were the M78, bought out by Dana.
Old Oct 6, 2009 | 07:13 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
good buy! been beating on one for 4 years now with prolly 450 hp and cheater slicks too. there are some stickys in here on the b/w 9 bolts with a ton of good info
Old Oct 6, 2009 | 08:28 PM
big gear head's Avatar
Are you sure that it's a Borg Warner? The 3.23 is a 10 bolt gear. There are good and bad points to both rear ends. The 9 bolt is a little better. The posi in the 9 bolt can be reconditioned at least one time.
Old Oct 6, 2009 | 08:30 PM
Stephen's Avatar
Car: 87 GTA
Borg Warner bought Dana years ago, so it's "technically" a BW now.
Old Oct 6, 2009 | 08:56 PM
??? How did Dana come into this?
Old Oct 7, 2009 | 04:56 AM
tomclayborn's Avatar
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
although what stephen said may be correct it is and always will be a borg warner... cars that went back for warranty with a g92 b/w got it replaced with a dana 44 which is the best stock rear and found in the front of older 4x4 chevy/ford trcks and in rear of wagoneers...200 seems like a good deal at any rate for it if u want rebuild one it would be really expensive www.9bolt.com has the prices of the parts to do it
Old Oct 7, 2009 | 11:22 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
there's no E in borg, it's not french.
d44 is in my bronco and all those guys hate how weak they are. For some reason 3rdgenners think they are great and pay a huge price since they are uber rare.
9bolts are great because they have 4-spiders. Last a long time behind and auto. I beat the crap out of mine behind a stick and made it whine, but it didn't break.
Old Oct 7, 2009 | 11:51 AM
The Dana 44 in the front of the Bronco is weak because guys put 33 inch or larger tires on them and the 28 spline axles can't handle it when you get the truck in a bind. Compared to the 7.5 inch rear ends that came in the third gen, the 8.5 inch Dana 44 is very strong. There are also MANY more options for differentials in the Dana 44. The BW only has one, and it's a cone type. I know a guy who has a third gen Dana 44 for sale, but he wants about $1800 for it.
Old Oct 7, 2009 | 11:11 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
I'm pretty sure there's an aftermarket locker available for the M78 in Australia.
Old Oct 8, 2009 | 07:04 AM
I've heard that there is something made in Germany for these rear ends, but it is extremely expensive.
Old Oct 8, 2009 | 07:21 AM
Twin_Turbo's Avatar
In Germany? Is this BW rear used in other cars? Maybe I can find what that German thing is.
Old Oct 8, 2009 | 11:55 AM
I read it on this sight somewhere. I might have misunderstood, but I thought it was Germany.
Old Oct 8, 2009 | 12:28 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Not sure about anything from Germany, but KAAZ from Japan makes an LSD for the 9 bolt. It'll run you about $1200 though.
Old Oct 8, 2009 | 01:53 PM
That's probably the one I was thinking of.
Old Aug 20, 2011 | 12:04 PM
ChevyRS-305's Avatar
That KAAZ is only for one pontiac and thats the 2004-2006 gto... deff not a 9 bolt...
Old Aug 20, 2011 | 12:15 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Despite the different axle assembly, I do believe that the center section is the same, which means the KAAZ would fit a 9-bolt.
Old Aug 20, 2011 | 12:19 PM
Is their anyone or anyway someone can verify this?
Old Oct 24, 2011 | 11:09 PM
mike_c's Avatar
GTO's don't have the same center sections. This KAAZ unit fits 9 bolts though:
http://www.efihardware.com/products/...y-LSD-DAG-3820
Old Oct 24, 2011 | 11:15 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Nope. Been there done that, even joined an Aussie board. There was a local Aussie outfit redrilling one for a Ford rear to fit, but they broke a lot. And for the price of the KAZ you can get a bolt in Ford nine with a truetrac.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
