Rear End ?
Old Oct 11, 2009 | 09:34 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Rear End ?
I have a 91 RS with stock 2.73 w/Drum brakes. And i want to do a full 3.42 Disk brake swap.
Does the higher gear throw off my spedomiter? and a new driveshaft?
Its a 5-speed Too
Old Oct 11, 2009 | 09:38 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Rear End ?
yes, speedometer gears will need to be changed. The driveshaft will be fine.
Old Oct 11, 2009 | 09:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Rear End ?
If you don't mind the rear wheels sticking out an extra 1.5 inches on each side, the cheapest easiest way to get this is a 4th gen rear from a 1998+ F-body - nice big LS1 disc brakes and 3.42 posi's are easy finds for about $250, and a direct bolt in (just have to do some rigging on the e-brake cable).
Old Oct 12, 2009 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear End ?
Following is general info about 10-bolts and all that you need to accomplish a swap, to include master, proportioning valve and e-brake cable.
https://www.thirdgen.org/forums/tran...-10-bolts.html
BTW, Camaronewbie, Ed Miller now has custom cables for the LS1 swap:
http://www.flynbye.com/catalog/i153.html
Here's a link to T-5 speedo gears and a how-to for install:
https://www.thirdgen.org/forums/tran...ve-driven.html
JamesC
Old Oct 12, 2009 | 07:41 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Rear End ?
where are those located?
Old Oct 12, 2009 | 07:47 AM
JamesC's Avatar
Re: Rear End ?
Check the last link I provide. BTW, you'll need to swap both drive and driven gears.
JamesC
Old Mar 9, 2010 | 03:01 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Rear End ?
random question, i have the ebrake cables from the 95 camaro, but i think they are about 3 inches shorter than my original ebrake cable.
should i just modify the original cable?
Old Mar 9, 2010 | 03:07 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear End ?
It would have been better to start your thread. Or even better, do a search since this has been covered. Like maybe in the 4th gen axle swap threads?
Anyways....You can cut both & splice your 3rd gen cable to the 4the gen cable, or buy one specifically made that way. I don't recal who. but I know at least one of the TGO sponsors has them.
Old Mar 9, 2010 | 05:49 PM
JamesC's Avatar
Re: Rear End ?
Personally, I'd purchase the correct cable. Check the first link I provide for the info you need.
JamesC
Old Mar 9, 2010 | 08:11 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Rear End ?
id like to but im on a budget, cant afford 100$ cables
Old Mar 9, 2010 | 08:27 PM
JamesC's Avatar
Re: Rear End ?
RockAuto has them for $20.79 per.
JamesC
Old Mar 9, 2010 | 08:44 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Rear End ?
wow, thanks alot man. You sure there 1434mm?
its a 91 RS
Stephen's Avatar
Car: 87 GTA
Re: Rear End ?
JamesC
Rockauto sells the adapter cables?
Old Mar 9, 2010 | 08:49 PM
JamesC's Avatar
Re: Rear End ?
its a 91 RS
Oops, 91, my bad. Check to see if you have the tunnel-mounted adjuster. If so, you need the first design. If there is no tunnel-mounted adjuster, you need the second design. Check post #4 of the following link for a pic and info:
https://www.thirdgen.org/forums/brak...r-e-brake.html
JamesC
Old Mar 9, 2010 | 10:05 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Rear End ?
mines a non- adjustment, so i need the 1460mm.
thanks alot man!
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
