700R4 Torque Converter Lock Up
Old Dec 5, 2009 | 12:00 PM
afastyzfr1's Avatar
I have a 86 Camaro Berlinetta with a V6 2.8L. The torque converter doesn't lock up automatically, but I added a switch and can lock it up manually. The temperature gauge on the dash doesn't work. Can anyone point me in the right direction to fix it?
Old Dec 8, 2009 | 03:32 PM
afastyzfr1's Avatar
Re: 700R4 Torque Converter Lock Up
Turns out my thermostat was stuck open and car was running cold. I have fixed that issue converter still doesn't lock up. Any ideas?
Old Jan 1, 2010 | 09:47 AM
afastyzfr1's Avatar
Now the car runs at normal temp, the torque converter tries to lock up occasionally. I can lock it up manually whenever I want so I think trans is ok.....any ideas?
Old Feb 11, 2010 | 07:29 AM
afastyzfr1's Avatar
The lock-up has started engaging erratically (on and off within a few seconds) even at steady throttle on flat ground.
ANY IDEAS?
Old Feb 11, 2010 | 08:39 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, get rid of that manual switch and go back to the stock set up. Why you need a manual switch on a 2.8 V6???
Old Feb 11, 2010 | 08:45 AM
afastyzfr1's Avatar
It is on stock set up. The converter used to not lock up at all, so I put a switch on to lock it up on the highway.
Old Feb 11, 2010 | 11:02 AM
DJP87Z28's Avatar
If it is a 700R4 it should lockup at 40 MPH in OD, if not get it fixed. A manual swich for you is a bandaid.
Old Feb 11, 2010 | 02:14 PM
afastyzfr1's Avatar
huh....it tries to lock up in 3rd also
I know it's a band-aid, but I put most of my car funds into my 4th gen 700 hp camaro
Just trying to figure it out myself since I do all of my own work.
Old Feb 11, 2010 | 03:50 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Most likely cause of erratic lockup is the brake switch although if you're manually having it lock by jumping the ALDL terminals and it works that rules out the brake switch. A test light across those terminals will also show whether the ECM is commanding lockup or not.
If the ECM is commanding lock/unlock erratically I'd look at the TPS. Erratic TPS voltage confuses the ECM into 'thinking' the throttle position is changing. Same with MAP readings but the TPS is more prone to failure in my experience.
Old Feb 11, 2010 | 04:27 PM
afastyzfr1's Avatar
THANKS!
Finally some useful info
Old Feb 13, 2010 | 01:05 PM
afastyzfr1's Avatar
Well TPS was in adjustment....and tested with voltmeter and it is fine
I will test computer and see when it is commanding lock-up when I get a chance
Old Sep 6, 2010 | 06:01 PM
afastyzfr1's Avatar
Installed a new 700r4 and converter. Tans stays locked in all gears except 1st and reverse. It will unlock if I press brake. I also removed my manual switch.
Is there a pressure switch and if so where is it?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
