4th gen rear end
Old Dec 27, 2009 | 02:32 AM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
4th gen rear end
I know that there is a tech artical about this and I plan on doing this to my car I just wanted to double check that it is okay to use a 2002 SS rear end on my 91 Z also what do you guys think about the price and what is the stock gear ratio on this rear? if its still stock of course, also is there anything bad to run into going with a 4th gen rear??
Here is the link
http://losangeles.craigslist.org/ant...523234864.html
Old Dec 27, 2009 | 02:42 AM
Brendan91Z's Avatar
Axle/Gears: Stock
Re: 4th gen rear end
I found the subject i figured that it has been answered i apologize https://www.thirdgen.org/forums/tran...rend-swap.html what about the price of this one??
Old Dec 27, 2009 | 10:40 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Guess it's probably OK - I paid about 1/2 that for mine, but I'm on the opposite coast where we don't have movie stars, so things cost less.
On the gearing and whether or not it's actually a Posi rear - the only way to truly know is to pop the cover - for $400 if the seller wont let you remove the cover to verify gears/posi I'd definitely pass.
Old Dec 27, 2009 | 01:32 PM
Brendan91Z's Avatar
Axle/Gears: Stock
thats what i was thinking if he doesnt let me than he can sell it else where. 400 seems a little high in my opinion my buddy got his for exactly what you got yours at If it is a true posi and everthing looks up i will talk the guy down are they like usually 3.42's?
Old Dec 27, 2009 | 07:06 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
spin the d-shaft and count the revolutions that will give you the gearing.
when you turn one wheel forward dose the other go forward or backward?
posi= both forward right?
maby im mistaken
Old Dec 27, 2009 | 08:08 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
maby im mistaken
With the zexel posi, you can't do the traditional posi check. You will have to pull the cover to verify it does have a posi.
And the seller didn't state what trans was in the car. A 6 spd. car should have a 3.42, but again the only way to be positive is to pull the cover and count.
I paid $250 for the same thing with a 3.42 ratio. Took the brakes off, and sold the rear with gears and posi for $200. Was a very happy camper to say the least.
Old Dec 27, 2009 | 08:21 PM
red30011's Avatar
Does any one have a link that shows the internal differences between an open and posi rear end? Be spending most of this week looking for one and would like to try and make sure its a posi. Hoping to find a zexel
Old Dec 27, 2009 | 08:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You can see an open as well as several kinds of limited slips in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 28, 2009 | 06:16 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I gave $140 for my disk rear from a 94 z with 3.23s. swapped in a set of 3.73s and love it.
Old Dec 28, 2009 | 08:05 AM
Brendan91Z's Avatar
Axle/Gears: Stock
well i gotta say im glad everyone is having a good experiance with the swap because i am dead set on it
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
