LT1 torque spec differences
Old Dec 27, 2009 | 09:30 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I remember seeing something about there being torque spec differences between LT1 T56's, and LS1 T56's. Is this true? I searched, but couldn't find.
Old Dec 28, 2009 | 07:53 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: LT1 torque spec differences
On the bolts? Or the warranty ratings?
The '93 M29 T56 were factory rated at 360lb-ft
The '93 M28 T56 were factory rated at 400lb-ft
The '94-'02 MM6 T56 were factory rated at 450lb-ft
The later model years got improvements in parts, but they were mostly reliability/longevity related. Once the common wear/failure parts are replaced in any MM6 unit, the ratings can all go to 700lb-ft. (limit of the mainshaft and gears)
Old Dec 28, 2009 | 11:45 PM
Car: '91 LS6/T56/9"
Engine: LS6
I meant bolts sorry.
Old Dec 29, 2009 | 08:01 AM
85MikeTPI's Avatar
All the bolt TQ specs are the same between the LT1 and LS1 T56s. They are listed in the back of the Tremec Service Manual.
Old Dec 29, 2009 | 08:34 AM
Car: '91 LS6/T56/9"
Engine: LS6
any difference on the pressure plate bolts? I've heard some talk of there being a difference.
Old Dec 29, 2009 | 09:19 AM
85MikeTPI's Avatar
Yes.. I consider the clutch/FW more engine specific than trans. The stock LS1 is 52#, the stock LT1 is 22#. Aftermarket clutches will have their own specs, so check carefully.
Old Jan 4, 2010 | 05:03 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Mike, I thought the M29 (2.97 1st) was rated at 400lb-ft and the M28 (3.36 1st gear) was rated @ 360lb-ft?
Old Jan 4, 2010 | 07:53 PM
85MikeTPI's Avatar
I probably have the 28,29 mixed up.. But yes, the higher (numerical) 1st gear unit has the lower TQ rating. (More, thus smaller teeth)
Old Jan 5, 2010 | 06:07 AM
Car: '88 GTA
Engine: L-98
Ok, just making sure the info I had was correct.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
TreDeClaw
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
