torque converter bolt tips?
Old Jan 16, 2010 | 07:07 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Is there any trick to getting the bolts that hold the torque converter to the flywheel off? I tried soaking the bolts in WD-40, heating with a torch for a couple minutes, and using an impact wrench with a u-joint.. The impact wrench got one off, didn't budge the other two (and eventually broke the u-joint )
The only thing I can think of doing is pulling off the oil filter so I have more room to work and sitting with a torch until the bolt is red hot.. Unless there's some other way to do it that I just don't know about
Old Jan 16, 2010 | 07:11 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: torque converter bolt tips?
I would try removing oil filter, or using a breaker bar. get some penitrating oil....wd40 oesn't always get in there good.
Old Jan 16, 2010 | 08:15 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Just ran and got a new u-joint and some liquid wrench. Hopefully that'll work a little better..
Old Jan 17, 2010 | 10:58 AM
da_jester's Avatar
Car: 1992 camaro rs
your not spose to heat up the bolt. heat causes things to expand and if you heat it up until its red hot and twist on it your probably just going to break the bolt head off in your socket id get some aerokroil or pb blaster and spray it a few times and let it soak in then use a breaker bar on it
Old Jan 19, 2010 | 08:10 AM
Pat Hall's Avatar
I just removed them on my 89 L03 after a lot of years, and mine were ridiculously tight too! What I figured out is if you have your starter out of the way and you rotate each bolt around to that position, an impact wrench works wonderful! You can fit an impact wrench up in there where the starter motor is. I had to use my big 1/2" impact, but it broke them loose like it was nothing. Using breaker bars and all that other crap, all I was managing to do was having to fight the motor turning as I tried to loosen them. Using a torch might not be a good thing for your converter either.
Old Jan 19, 2010 | 08:54 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I don't know what was up with the two that were stuck. The first one I used the impact wrench on came off real easy, the other two it just sat and banged away and they didn't budge.
Heat ended up working for me, I sat with a torch on the two that were stuck for about 5 minutes each and then used the impact wrench and they came off like nothing. I really wasn't too worried about the torque converter or the flexplate, neither is getting reused..
Old Jan 19, 2010 | 06:08 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
geeze i am jealous of you guys, my tq convertor bolts just fell out at a stop light, it ran me a bill of 98$ for towing They must not have been tight enuff lol
Old Jan 20, 2010 | 01:34 AM
Pat Hall's Avatar
That's cool, sounds like it worked out good. Yeah, if you're trashing the converter/flexplate then who cares right? Hey Big J, make sure to use some med. strength Loctite (blue #242) on both the flexplate and torque converter bolts, and torque them to spec and you shouldn't have any problems with them coming loose. The part that really blew me away when I was taking mine apart was that the flexplate bolts were so tight I ended up rounding off the head on one of them and splitting the 6 point impact socket I was using! I had to drill into the bolt, then use a hammer and chisel to knock the head off so I could get the flexplate off. I bought nice ARP 12 point bolts to replace them with, so I shouldn't run into that problem again hopefully! The old 2 pc. rear main motors have bolts with a nice, big 3/4" head, and I've never had any problems with those, but the 1 pc. rms motors have those puny, 9/16" headed bolts, so it's not hard at all to round one off. The bolts are so close to the center hub of the crank that you can't use the older bolts with the bigger head.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
