what is it called?
Car: 90 formula
Transmission: auto
what is it called?
the piece you can manually shift thru the gears from under the car like on a auto 700r4. i need one and google shifter and what not and cant find it anywhere because i need a new one.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: what is it called?
what are you talking about? you want a manual valve body for the trans? not a good idea on the street, will kill the trans fluid quick, or a manual trans with a clutch and everything?
Car: 90 formula
Transmission: auto
ill get a pic tomorrow.
its the piece you can get under the car and manually shift it from park reverse neutral thru 1st.the gears on a automatic trans if you have the cable undone from the shifter.
