9 bolt drum to disc
Old Jan 28, 2010 | 08:23 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
9 bolt drum to disc
i have a donor car in my driveway now and have everything that i believe i need. brake lines and prop valve the whole nine. however mine is an 85 rear and the disc one i have is an 89. will there be any brake line problems???
also i was reading that the axle flange is different and i wont get the rotors on my old drum set up. is it just a matter of changing the axles over as well??
Old Jan 28, 2010 | 08:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9 bolt drum to disc
If your 85 has the cast iron proportioning valve (instead of the alum version), lines there will be SAE and the 89's combination valve will be metric. With a donor car, however, you should be able to scavenge whatever parts you should need.
The axle flange is indeed different. You'll need either to modify it or purchase the bolt-on kit from Ed Miller. IIRC, you won't have to change the axles if you use a rotor from 93-97.
JamesC
EDIT: If you haven't seen the following post, check it out. You might have special interest in post #13.
https://www.thirdgen.org/forums/brak...drum-rear.html
Old Jan 28, 2010 | 09:13 PM
Car: 85 trans am
Engine: 383 stroker
ok...my next question is if i buy rotors for a 95 camaro will i still need the bolt on kit or still need to modify the axle?? short on cash and wanna take the cheap route right now. will need new rotors anyway so will either changing the axles or changing to a 95 rotor. would like to change the axle if that would do the trick or maybe the rotors. if i did the axle swap i could still stick with the proper rotors tho. what do you think about that??
Old Jan 28, 2010 | 09:21 PM
JamesC's Avatar
To accomplish what you wish to do, you'll have to modify the flanges, which is the cheap way out, or purchase the kit, which is the simple way out. One way or another, you'll either need new axles which are in the $200+ range, or the aforementioned rotors which are a whole lot less. So the cheap route is to mod the flanges and buy rotors.
JamesC
Old Jan 28, 2010 | 09:23 PM
Car: 85 trans am
Engine: 383 stroker
well i have the axles that are in the 89 car thats in my drive as long as they are all the same length and splines they should only be different on the ends right???
Old Jan 28, 2010 | 09:29 PM
JamesC's Avatar
Both your 85 and 89 should have 26-spline axles--double-check the 89 as some 28-spline axles apparently found their way in in that year. Should work fine (the rotor swap would be less time/labor intensive). Here's another link that might prove useful:
https://www.thirdgen.org/ls1reardisc
JamesC
Old Jan 29, 2010 | 07:24 AM
JamesC's Avatar
Brain fart: All 9-bolts have 28-spline axles and also have different length axles side to side. As a consequence, they won't swap into a 10-bolt, though I assume your 89 is a 9-bolt. Also, 9-bolt axles apparently are the same for both drum and disc brakes.
https://www.thirdgen.org/forums/tran...le-shafts.html
JamesC
Old Jan 29, 2010 | 04:12 PM
Car: 85 trans am
Engine: 383 stroker
well both are nine bolts. are the axle flanges part of the axles or part of the rear housing? if part of the housing i may just swap the whole rear.
Old Jan 29, 2010 | 04:22 PM
JamesC's Avatar
Housing.
JamesC
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
