parking brake adjustment.. help
Old Feb 14, 2010 | 07:56 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I have an 87 trans am with the rear axle from a 2002 camaro ss. 3.42 posi and the 11" brakes. The parking brake will engine slightly, but if im anything slopy car will roll. How do i adjust this?
Old Feb 14, 2010 | 08:09 PM
pgmonster's Avatar
Car: Firebird Pro/Am
Engine: 5.0 TBI
Re: parking brake adjustment.. help
do you have the hand brake or foot pedal?
i think most are hand
so for that you take off the center console and there should be some adjustments on the handle
Old Feb 14, 2010 | 08:12 PM
Engine: 383 Stroker
Transmission: t-56
sorry meant engage, not engine. And its on the handle you say? Is just like a nut you turn of is there a special procedure?
Old Feb 14, 2010 | 08:21 PM
pgmonster's Avatar
Engine: 5.0 TBI
depends rear disc or drum?
Old Feb 14, 2010 | 08:42 PM
pgmonster's Avatar
Engine: 5.0 TBI
i just looked at mine you should see something like this
if you have this type you should just Remove the protective cover from around the park brake handle. loosen the jam nut on the adjusting rod and turn the adjusting screw until the cables tighten and then thighten the jam nut to hold the screw in place rotate the rear wheels to ensure they are not binding and its that simple
Old Feb 14, 2010 | 08:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The adjustment is in the tunnel above the drive shaft--doesn't matter if the rear is disc or drum. Look at post #4 of the following link for a pic:
https://www.thirdgen.org/forums/brak...r-e-brake.html
Since this is an LS1 rear, how have you hooked the cables up? Either a modification of some sort was done, I assume, or you purchased cables from Ed Miller.
BTW, no thirdgen, to my knowledge, was ever equipped with a foot foot pedal.
JamesC
Old Feb 14, 2010 | 08:53 PM
pgmonster's Avatar
Engine: 5.0 TBI
it should only be above the driveshaft if you have a manual tranny or
foot pedal(Which usualy is only on four wheel disc) but idk did you change it when you put the rear end in it?
Old Feb 15, 2010 | 08:48 AM
JamesC's Avatar
Regardless of transmission and/or brake system, 82-89 thirdgens have an adjustment mechanism in the tunnel above the drive shaft. New models, 90+ feature a self-adjusting parking brake. All parking brakes are applied using a handbrake.
Ilike,
If you're using the LS1 cables, unmodified, that's you problem. Check the following link, toward the bottom, for info on LS1 cables:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
