91 formula borg warner 9 bolt rear wheel seal help!!!
Old Mar 24, 2010 | 10:06 AM
Chris67rs's Avatar
Car: 91 Firebird Formula WS6
Axle/Gears: 3.27 9 bolt
I have a 91 formula (305e) with a borg warner 9bolt from a 87 ta, it has discs, the passenger side wheel seal is leaking, how do I remove the axle to get this wheel seal replaced?
I have heard tha t 9 bolts dont have C clips like 10 bolts do. is there anything special that I need to do or just unbolt the wheel and caliper bracket and pull? do i need to remove the bearing from the axle or is it pressed into the tube? any help would be appreciated, ive searched here and all over google but no real steps for the 9 bolt , all c clip stuff.
thanks!!!
Old Mar 24, 2010 | 02:50 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Re: 91 formula borg warner 9 bolt rear wheel seal help!!!
you will need to take the disc hat off, and unbolt the retainer from the housing end, 4 bolts. thats the easy part. A slide hammer and the assembly will pull out, and you will be left with an axle assembly consisting of these things in this order:
axle>>retainer plate>>axle seal>>bearing>>bearing sleeve.
now for the painful part. all that stuff to the right of the seal needs to be pressed off to get to the seal. while you are there, it might be useful to replace the axle bearing. you will most likely damage the retainer ring getting it off, so you will need a new one.
Old Mar 24, 2010 | 02:57 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Remove the wheel,caliper assembly,and rotor. Then remove the 4 nuts holding the axle in place. Then remove the axle, you may need to use a rubber mallet against the back side to pop it loose or some other form of persuasion. Try not to rotate the axle during removal as there are two sets of splines in the carrier and they will become misaligned and make reinstallation difficult. Yes, the bearings are on the axle and will have to be removed to replace the seal so might as well do both axles since you're in there.
Old Mar 24, 2010 | 05:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Bearings will be junk after being pressed off and you will need replacements (Timken SET-9 or its equivalent part number) for the oil seal Ratech RAT-6131 for the passenger side/driver side RAT-6130. When looking for parts for the 9-bolt, try searching under GM 7 3/4 rear.
Old Mar 26, 2010 | 05:43 AM
Chris67rs's Avatar
Thank you both, I managed to get it all off (wasnt hard) did not need a slide hammer, just yanked real hard a few times and the axle popped out, the seal was toast, the bearing looked good, but got a new one with the parts listed. the seal was special order (go figure) but it came in overnight, took it to my local auto place that has a press and they did it all for 25 bux, the rear was in great shape, I bought it from this board a few years back (like5 yrs?) and it was redone then, I guess because I let my ride sit so much (only drive it like 25-40 miles in a year) it had a dry spot that ripped when I moved the car. I picked up the completed axle last night and put it back in , so im back in buisness, thank you both for the help, its priceless.
Chris
Old Jan 5, 2011 | 03:57 PM
gufnstuf's Avatar
thanks for this post it was exactly the info i was looking for. my drivers axle slides in and out about 3/8". is that the space where the seal used to be probably?
Old Feb 16, 2011 | 09:55 AM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
DJP87Z28 ,
you wouldnt happen to know the part number to the pinion seal do you?
or are they the same seals?
thanks
Old Feb 16, 2011 | 12:48 PM
jwscab's Avatar
Engine: Many
autozone lists this part as the pinion seal:
7457N
driver side seal:
224255
passenger side:
710179
check autozone or rockauto for parts when you need to look something up, very helpful and organized relatively decently.
Old Feb 16, 2011 | 06:25 PM
Axle/Gears: 3:27
thanks for your help
Old Feb 16, 2011 | 09:00 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Not trying to hijack this thread, but those 4 bolts wouldn't happen to be the ones that are holding the Caliper Mounts on are they? If they are, Can i pop out the axles and pop em back in without changing anything?
Old Mar 7, 2011 | 04:51 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Yes they are, but you wont be able to move the caliper off of the disc in order to slide the axle out if you leave the caliper mounted to the mounting plate. Its only 2 extra bolts anyways.
About popping axles in and out without chaing anything, sure you can, but why do you want to take it out if nothing is wrong with it? (if it aint broke, dont fix it?)
Old Mar 7, 2011 | 05:06 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree with the above. Remove brakes, remove the 4 bolts on the retaining plate. The axle will pull out. It may be easier to mark the orientation prior. It took longer for me to re-align the splines afterwards to get to the axle to go all the way in. I removed mine to put in some new ARP wheelstuds last Fall since the new studs would not go in with the axle installed.
Old Mar 7, 2011 | 06:01 PM
383 Power's Avatar
I was considering changing the Caliper mounts to ones from a 93-97 Camaro.
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
hectre13
Aug 26, 2015 08:17 AM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
