700r4 problem
Old Mar 26, 2010 | 07:30 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
700r4 problem
I installed this 700r4 under the assumption that the tranny had 5000 miles on it and in great working order. It was built by a guy that knew what he was doing that has built multiple transmission for other people with no hiccups.
So my problem is when i put the car into neutral it lunges ever so slightly forward.
I double checked my linkage and when the shifter is in any gear i can take the pivot pin and it comes in and out of the selector's hole on the side of the tranny fine. I am putting the pivot pin in the right hole i triple checked my linkage and pivot pin placement.
I bought a new TV cable (also known as Detent according to advance auto and auto zone) and am waiting for the temps to get up above 20* until i install it. My current TV cable doesn't rachet when you open the throttle.
I have all the appropriate brackets. And have made sure to everything is hooked up right (checked at least 3 times over.)
The tanny is a little on the full side also so could that be causing the problem? Its a little above the hot mark when its cold or just sitting there.
Any input would be great.
Thanks Everyone
Old Mar 26, 2010 | 11:04 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Re: 700r4 problem
You might not have enough clearance in the forward clutch pack, all so check the position of the manual valve with the pan removed some times the link between the shift lever (AKA roster comb)and manual valve is bent. You may have a cross leak in the pump or a cracked input shaft. good luck
Old Mar 27, 2010 | 09:10 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: 700r4 problem
Can this all be checked by pulling the pan?
I will take a look at my rebuilding books to try and locate the above mentioned parts. Is the only way to replace the parts by pulling the tranny and rebuilding?
Old Mar 28, 2010 | 11:09 PM
sgt473's Avatar
Car: 87 Z28
Engine: LB9
Transmission: 4L60
Axle/Gears: 2:73
Re: 700r4 problem
You should be able to check all but the clutch clearance. The linkage can be replaced by removing the trans pan.
Old Mar 30, 2010 | 12:17 AM
Pro Built Automatics's Avatar
Re: 700r4 problem
I gather a tight foward clutch clearance could cause this, but i would not worry about this as I have seen this many times over the years, and in many different types of transmissions.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
