rear end
Old Apr 6, 2010 | 12:08 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
rear end
I was wondering if this would be a good choice for a 383 stroker about 400 HP is what I am aiming for... I want both wheels to grab and slip when on turns...
http://www.summitracing.com/parts/MSR-12BHBFCBBDXX/
Old Apr 6, 2010 | 12:21 AM
Stephen's Avatar
Car: 87 GTA
Re: rear end
That appears to be nothing but the housing & axles. It says nothing about the ring & pinion or differential (posi/open/locker etc.)
Old Apr 6, 2010 | 12:25 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: rear end
are you sure? I scrolled down and that's where it says True Trac ... then it says 3.73... then axle shaft spline qty 33
Old Apr 6, 2010 | 12:31 AM
Stephen's Avatar
Car: 87 GTA
Re: rear end
I see where you read that now....I read the description at the bottom "They include a steel housing, axle shaft set with wheel studs, bearings, and drain plug."
Maybe your right.
I only paid $300 more for my WHOLE CAR! Damn that rear axle is expensive!
Old Apr 6, 2010 | 12:33 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: rear end
lol.... I'm still not sure if I am gonna dump money into it just yet... gotta take the front bumper off and see what type of damage it has if any underneath... I'm kinda window shopping atm....
Old Apr 6, 2010 | 01:48 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: rear end
Old Apr 6, 2010 | 09:34 AM
aks's Avatar
aks
Car: 92 Z28
Re: rear end
My buddy has a 12bolt moser in his 84 ta and he loves it. It has 4.88 gears with an ls1/t56.
Old Apr 6, 2010 | 10:42 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: rear end
Damn 4.88!!!! He only uses his car at the strip?
Old Apr 6, 2010 | 01:00 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: rear end
I wouldnt replace it until you had to
Old Apr 6, 2010 | 01:23 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: rear end
well yeah, but I have 2.73 gears right now...
Old Apr 7, 2010 | 07:14 AM
3rdgenmaro's Avatar
Car: 88 IROC
Re: rear end
Then buy a set of used 3.42s and have them installed. Should be less then $300 and will last you a while. Even less if you know how to set up the rear yourself. You could also possibly find a good rearend from a 3rd or 4th gen camaro/firebird with posi and better gears for pretty cheap. Then there is also the 8.8 Ford swap. Just trying to throw out some ideas for ya. Those 12 bolt units arent cheap
Old Apr 7, 2010 | 07:47 AM
tekkitan's Avatar
Car: 87 IROC-Z
Re: rear end
Could get a 9inch housing/axle assembly from Moser as well (listed on Summit for third gens) they are only $1000-$1500. Then goto a junkyard, craigslist or ebay even and find a 9inch third member and rebuild it (or get it rebuilt).
12 bolts are nice too, but I hear it is a lot easier to change gears in a 9inch than a 12 bolt.
Old Apr 7, 2010 | 07:40 PM
aks's Avatar
aks
Car: 92 Z28
Re: rear end
Yeah I kid you not 4.88s haha. He only uses it for races, but he does drive it on the road from time to time. Extremely fast car.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
