Has anyone fabricated a T56 "Hump Style" crossmember?
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
If so, do you have any pics? I'd like to do this. I have the normal Skulte crossmember and my exhaust has literally 2" clearance at the y-pipe. Any help is appreciated.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Has anyone fabricated a T56 "Hump Style" crossmember?
I'm making mine this Saturday. I'll post pics of what I make
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Since Andris officially closed up SPD, I don't feel too bad about posting these pics.. He used my car for the proto-type SPD double-hump T56 xmem..
I never formatted the pics, just raw as they came out of the camera:
http://www.eecis.udel.edu/~davis/z28/2006/060115SPD/
Afterwards, I built and welded up a bracket to it for my Spohn TQ arm:
http://www.eecis.udel.edu/~davis/z28...CP_%20001.html
Mike, do you know what size tubing he used for that? I was going to use flat plate strenghtened by square tubing welded to it but that looks stronger and easier in the end.
It's 1x3" box tubing. Mild steel. The end pieces that bolt to the sub-frames are 3x3 angle steel.
Car: 91 Firebird
Engine: Turbo 355
Wow. Very helpful Mike! My plan was to chop up my straight style skulte crossmember and salvage the mount piece as well as the two angle pieces that mount to the subframe. I would like to use anlge iron though. Not sure what your take on that would be?
I just called a few places near me and I'm not sure I'm going to be able to get boxed steel so mine my still be made out of angle iron, flat plate, and some small square tubing to brace everything. I may even make box tubing out of flat plate and square tubing. I planned on using 3/16" for the angled pieces and flat plate. The square tubing is thinner though.
Car: 91 Firebird
Engine: Turbo 355
Also, Do you guys think I can just make one out of 3" x 1/4" flat stock?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I used 1/4" plate bent into a squared U around the trans mount... and 1/8" plate for the rest.
https://www.thirdgen.org/forums/fabr...6-gen-1-a.html
Alright well it took a lot longer than expected but I said I would post pics when done so here they are. I'm only posting two pics but if you click the cardomain link in my sig and go to page 3, there are a lot more pics of it.
This pic is before welding it all up. I also cut some of the ends sticking out off the crossmember before welding up. The pic above is after final welding though.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hmmm, not sure how well that will withstand twisting, but i guess we'll see
Its braced on both sides. I have more pics in my T56 swap thread at the bottom of the page. I also have solid motor mounts so its not going to be twisting much anyways. Its also made out of 3/16" steel so its fairly thick metal.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
Royal_Z
Sep 30, 2015 08:45 PM
tmork454
Sep 29, 2015 06:33 PM
1991, 3rd, body, build, building, crossmember, dual, fabricated, fabrication, gen, hump, size, t56, transmission, tubing, z28
