t5 stuck in 3rd gear
Old Apr 9, 2010 | 05:14 PM
lambo1238's Avatar
I have a 1989 rs 305 with a t5 I replaced the clutch and slave cylinder and it was driving fine. Later that night while my brother was driving it just got stuck in 3rd and won't budge at all. I was having trouble getting into 4th i had to either double clutch or bounce it in gear for awhile. Any ideas wtf I can do to fix it?
Old Apr 9, 2010 | 05:16 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: t5 stuck in 3rd gear
pull the trans and rebuild it.
Old Apr 9, 2010 | 05:30 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Make sure there is fluid in the line and its not leaking anywhere. Otherwise it sounds like its time for a rebuild as 1MeanZ suggested.
Old Apr 9, 2010 | 06:13 PM
lambo1238's Avatar
alright, thanks
Old Apr 10, 2010 | 10:55 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
broken gear selector fork. either way u need to pull the trans and pull the tail shaft housing off and the gear selector cover off. a similar thing happened to me, except it didnt get stuck in a gear... i only had first, second, and fith... heres the thread that i started when my t-5 broke. https://www.thirdgen.org/forums/tran...-5-please.html although i didnt break a shift fork... that piece did break and limit what gears i could use... and yes it broke as a result of being hard on it.
Old Apr 12, 2010 | 11:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Did you put the clutch fork back onto the TO bearing correctly? I made that mistake once and it was hard to shift up or down, but harder going down as the clutch wouldnt totally disengage.
Old Apr 13, 2010 | 04:19 PM
lambo1238's Avatar
Yea it was put in right. I pulled the trans and it still won't budge from 3rd. So I'm gonna rebuild it myself since I can't find one in a junkyard around here.
Old Apr 13, 2010 | 05:26 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Be sure to post up some pics of the damage!
Warlocksirix
Sep 3, 2015 12:26 PM
JHX
Aug 29, 2015 02:30 PM
suzuki949
Aug 28, 2015 08:07 AM
redmaroz
Aug 16, 2015 11:40 PM
