Help with T-5 Please.
Old Nov 20, 2007 | 09:14 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I recently did an engine swap but I kept my T-5 and all hydrolics for it. It was a LG4 to 305 TPI swap. I have done clutches on numerous T-5's and pretty much know how to do it so that not the problem.
My problem is that my trans wont go into gear... The shifter moves up into where the gear should be but nothing. I did replace the speedo gears. Could i have messed up the shifting mechanism?? if so how do I fix my problem?? Slave cylinder has been bled. Car has new clutch, flywheel, pressure plate and throw out and pilot bearing.
Any help would be appreciated!
Thanks,
Kyle
Old Nov 20, 2007 | 09:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Help with T-5 Please.
did you take the shifter off the trans? was the trans in neutral when you did it? it may be possible the shifter ball is not where it needs to be.
Old Nov 20, 2007 | 10:02 PM
L69norm's Avatar
Pin can out of the shifter or forgot to re-install the pin?
Old Nov 20, 2007 | 10:46 PM
86irocu's Avatar
Car: 1986 Iroc-Z
You guys talking about the pin for the selector block in the tail shaft?? I thought the trans was in neutral when I put it back together... There really isn't a way you can screw that up can you?? I think it is the gear box. When the car is running I can go through all the gears and nothing. no resistance. I pulled the shifter off again and checked the selector but everything seems to be correct. Could it be in the gear box?? How does that rod going into the gear box change the gears?? Any way that I could have messed anything up inside?
And for the shifter ball... It goes right underneath the spring in the shift selector right?
Old Nov 21, 2007 | 09:28 AM
Drive shaft installed?
Old Nov 21, 2007 | 11:20 AM
AC's Avatar
AC
Car: Used to drive a camaro
My TKO600 had a warning that came with the shipping / installation instructions. The paper said something about shifting forks / levers internal can sometimes shift during freight and to make sure the shifter moves freely in and out of all gears. Can move the shifter in and out fine?
Old Nov 21, 2007 | 08:56 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Yes the drive shaft is in. Its hard to forget that. And yeah. the shifter moves freely. I'm going to take the slave cylinder off tonight and start it with the car in the air and see if its the throwout bearing or slave thats not working right. I'll post up and let you guys know how it goes.
Old Nov 22, 2007 | 12:04 PM
What trans is it? What clutch? (part #s ONLY, and detailed description of where the trans came from or its clutch gear spline count ONLY ..... not "stock", "WC", etc.) Is this the same trans and the same clutch that was there before; or what?
Old Nov 22, 2007 | 02:53 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Yes same trans and clutch. I pulled the slave cylinder off today and put the car in gear and started it. Nothing. Tires didn't spin or anything. The trans came in an '86 irocz with an LG4 motor. As for the clutch it is a spec stage 1 disk and pressure plate. I'm pulling the trans tonight and i'm going to mess with it a little bit and see if i can fix it.
Old Nov 22, 2007 | 03:10 PM
I'm afraid that's the only thing left... I'm all out of guesses as to what you put together wrong. You'll just have to go back and check your work.
Old Nov 22, 2007 | 03:55 PM
86irocu's Avatar
Car: 1986 Iroc-Z
On second thought... i have to work at 4:30 in the morning... so i prolly wont get to it tonight... but tomorrow for sure. I'm thinking about taking the trans to a local trans shop to get it looked at because i have no clue about this thing...
Old Nov 22, 2007 | 07:21 PM
L69norm's Avatar
Originally Posted by 86irocu
.... How does that rod going into the gear box change the gears?? Any way that I could have messed anything up inside? And for the shifter ball... It goes right underneath the spring in the shift selector right?
The rod is connected to the shift forks (2). I've heard of people breaking a shift fork, but not 2.
See picture 3:
http://www.fordmuscle.com/archives/2...uild/index.php
It sound like the pin is either missing or it's not in far enough.
Old Nov 22, 2007 | 09:03 PM
86irocu's Avatar
Car: 1986 Iroc-Z
So your saying when i take that top cover off... the shift forks will not be attached properly??
Need i remind you that the trans was working fine before the engine swap and before i put the speedo gears in. Could I have pushed one of those pins out on accident while taking the tail shaft housing off or putting it on??
Old Nov 22, 2007 | 10:15 PM
L69norm's Avatar
No, I'm assuming that you didn't touch the top cover and there's no way that both shift forks could have come off. Even if one fork did manage to come off, the other one would still work so you would have at least 2 gears.
From your description, it sounds like it's stuck in neutral and no gears work (including 5th and reverse). The only way is either the is clutch stuck or the shift rod isn't moving (pin came out).
Is the shift rod actually moving with the selector block? I think the pin shown in picture 3 is either not in far enough or too far.
Old Nov 23, 2007 | 03:31 PM
86irocu's Avatar
Car: 1986 Iroc-Z
the block moves with the rod. pulled the slave cyl out yesterday and jacked the car up and ran it in gear and nothing. I was trying to see if it was the clutch but its not.
Old Nov 23, 2007 | 05:44 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Well I figured out the problem.
Can anyone tell me what this piece is called?? It holds the shift forks solid on the shift rod. With out it there is nothing to hold the shift forks so I cant shift the car.
where can i get it??
Also this is what the 5th gear needle bearings look like.
Old Nov 23, 2007 | 10:48 PM
L69norm's Avatar
It's been a while, but:
Thats the part#28 "interlock plate" (figure 5.2 page 5-5)
http://www.ttcautomotive.com/English...0-0199_173.pdf
Looks like you need 37,38,39,40,42 as well
I thought there was a tab on part 42 lines up with the notch in the extension housing as well a notch in part 38 when you slide the extension housing back on (at 1 o'clock). It almost looks like tab was at 10 o'clock and got bent over against the bearings when you slid the ext housing back on.
Hanlon Motorsports http://www.hanlonmotorsports.com/
You might be able to pull parts from a V6 or dead V8 T5 as well. Also check a few local tranny shops for their suppliers.
Gunner242
Dec 25, 2015 04:49 PM
jaridjohn
Oct 5, 2015 07:01 AM
luvofjah
Sep 26, 2015 08:28 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
DARKmj16
Sep 9, 2015 04:07 PM
