PICS: 4th Gen Rear Prep and Paint Before Install
Old May 4, 2010 | 03:19 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Hey guys. I figured I'd clean up and paint my 4th Gen rear assembly, while I wait for my proportioning valve purchase.
I'll start the thread with these pics and add new pics, as I progress through the cleaning and painting of the darn thing.
Here's when I first got it a few days ago:
Here it is yesterday, after removing the brake lines, calipers, and rotors and after degreasing and scrubbing the heck out of it. It's kinda nice that the abs wires/plug just unplugs from that sensor plug on top of the housing.
Scraping the caked on crud out of every nook and cranny was sort of a pain, but it's almost ready for the Rustoleum "Rust Reformer."
The rust seems impossible to get off. I'm painting it a two color pattern--black and orangish red. It should look sweet when I'm done. I'll post pics when it's finished.
Old May 4, 2010 | 03:23 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: PICS: 4th Gen Rear Prep and Paint Before Install
good luck should be good..
Old May 4, 2010 | 05:41 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I would suggest the POR-15 starter kit, if you want a paint job to last.
Old May 4, 2010 | 06:04 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Cool.....thanks. I'll check out the POR-15 kit. I found it. Looks like good stuff. I just got done hitting it with Rustoleum, then I saw your posting.
http://www.por15.com/SUPER-STARTER-K...ductinfo/SSKB/
Old May 4, 2010 | 06:15 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
That Rustoleum Rust Reformer is weird stuff. I never used it before. It dried white in a few places, and it's supposed to dry black. I'll sand it off a little where it dried white. I guess it wasn't quite as rusty as I thought in some places.
Before Rustoleum Rust Reformer
After Rustoleum Rust Reformer
Old May 4, 2010 | 06:20 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Another before and after:
Before Rustoleum
After Rustoleum
Old May 4, 2010 | 07:20 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Where can you get this POR-15 kit? I'm about to do a fourth gen swap as well and would like to paint my rear axle also.
Old May 4, 2010 | 08:14 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Look at the link I posted four posts up, Shady.
Here is how mine turned out with Rustoleum engine enamel. It looks much better, in my opinion.
Old May 4, 2010 | 10:57 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
What do you guys think?
Old May 4, 2010 | 11:13 PM
BigEd65's Avatar
Car: 1992 Chevy Z28 - Black
Engine: ZZ4 350 HSR w/ 100 shot
Transmission: Automatic - Hurst dual gate
Axle/Gears: Moser 12 bolt 3.42 Eaton gears
great job I also just bought a 4th gen rear and started braking it down tonight to start prep ...... might do a red and black similiar combo with a new aluminum finned cover
did yours come with the LS1 brakes ?
Old May 4, 2010 | 11:31 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Thanks.
It came with whatever brakes are on a 97 Camaro Z28. I know they're disc brakes but that's all I know.
Old May 5, 2010 | 05:18 AM
DJP87Z28's Avatar
Order it on-line from their site, about $20 for the complete kit. It will be more then enough to do the job plus other touch ups.
Old May 5, 2010 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
93-97 = LT1
98+ = LS1
The LT1 PBR's are, for the most part, identical to the 89-92 version. The LS1's look much different.
JamesC
Old May 5, 2010 | 06:38 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
Looks good man. I can't wait to find a nice one to swap in because LS1 rear discs will be a huge difference over my stock drums. I plan to prep and paint mine too and also install a TA diff cover. Keep us posted on the install.
~Matt
Old May 5, 2010 | 10:01 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I'll post up pics of my car, with the 4th gen rear. I'm imagining the tires being just about even with the fender wells.
~Matt
Old May 5, 2010 | 10:48 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
From what I've read on here about this swap the LT1 axle is a few inches wider so the wheels will still out the sides more. Also the 15 in wheels may not fit the rear brakes without adjustments, but that might have been only for the LS1 rear. I'm not sure if you had stock 15 inch wheels on there like many of the 1986 Z28s came with. There is a sticky that has the info.
~Matt
Old May 5, 2010 | 10:54 AM
JamesC's Avatar
From what I've read on here about this swap the LT1 axle is a few inches wider...
There's info in the following link about the width of the two fourthgen axles, should anyone be interested:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 5, 2010 | 06:42 PM
Engine: 350 S/B
The paint job looks awesome. Did you spray it with clear coat? I'm ordering my POR-15 kit now, so I can paint mine as well.
Old May 5, 2010 | 07:09 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
No clear coat...just Rustoleum "Hammered Look" for the axle tubes and Rustoleum engine enamel for the housing.
If it lasts a while, great...if not...oh well.
Old May 5, 2010 | 07:14 PM
Engine: 350 S/B
I got the black POR-15 kit, but plan to paint the housing a different color. What color do you guys think would be best? I was thinkin either orange or red.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
