4l60e / 700r4 how to install new reluctor ring
Hey guys, Like a fool I cut the old ring off the 96 4l603 thinking i could just put my plastic speedo gear on there and the computer didnt need it, so I have a new reluctor ring to install, 40 tooth, how do I get it on there? I had to cut the old one off...
thanks
thanks
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 4l60e / 700r4 how to install new reluctor ring
Really, really old thread, but I'm actually in this situation right now lol...
Axle/Gears: '01 3.42 10 bolt
it presses on. you might bend it trying to tap it on with a hammer. if the transmission is apart, it's easy. if not....
Car: 1984 Trans Am
Car: `86 SS / `87 SS
Tap tap tap.
A pipe that presses around the reluctor evenly is better than tapping around every side repeatedly. Plus, you won't damage the teeth.
Car: 1984 Trans Am
I tried tapping it last night but with the trans assembled, I have no leverage. I'm going to have to go with a three jaw puller and try to get it out that way.
Engine: 4++,350 & 305 CIs
A little heat works too
Car: 1984 Trans Am
Doesn't need much heat, go easy
Car: 1984 Trans Am
If you're removing it, put a cheap open end wrench (spanner for a grinder, etc.) under it and tap from the trans. side. That gets it off the T5 and T56 stuff. A pretty weak 2 or 3 jaw puller with straps to extend the jaws will should get it done at llast resort.
hectre13
Dec 11, 2023 08:14 AM
1996, 40, 4l60e, 700r4, impala, install, installation, installing, reluctor, removal, ring, tool, tooth, transmission, vss
