T5 clutch replacement
Old May 13, 2010 | 07:30 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Im getting ready to replace the clutch and flywheel on my 92 5.0 5speed.I was wondering if I should put a lighter flywheel and performance clutch,or just put stock back in it.I kinda want to go with performance stuff but not sure what I should use.And if its even worth it on a bone stock 5.0
Old May 13, 2010 | 09:31 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: T5 clutch replacement
i just replaced mine a couple of month's ago . if your just a regular driver with an urge to kick it once and awhile a stock clutch , T.O. bearing , pressure plate is fine . an important thing is inspect teeth on flywheel , and get flywheel re-surfaced . re-surface is a must do that many overlook . many are sorry later . good luck .
Old May 13, 2010 | 10:04 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
I had my clutch done a few yrs ago and they didnt resurface the flywheel,so now it chatters alot and thats why Im thinking of having it done again.
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
