strange 9" tidbits
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
strange 9" tidbits
I bought a strange 9" direct bolt in from craiglist, and i couldn't resist: i had to tear it apart. It is a strance center section and housing with 4.10 gears, 35 spline axles, and a detroit locker. this is what i bought: https://www.thirdgen.org/forums/engi...9-3rd-gen.html
first, when i drained the gear oil, it was had metallic powder in it (from what i believe to be break in oil)
second, they used grade 8 bolts for the ring gear... can upgrade them to arp bolts? arp ring gear bolts
can i change the socket cap screws on the main bearing cap to arp studs? http://www.jegs.com/i/ARP/070/250-3004/10002/-1
josh
what gear oil should i use for a detroit locker?
josh
Car: '88 Camaro (Gone...)
Re: strange 9" tidbits
Not really contributing to what you're after, but what's wrong with the grade 8 hardware that makes it worth replacing? To me it just seems like a waste of money, but whatever floats your boat
As for gear oil, just be sure to use synthetic IMO, no reason not too. Personally I like the Lucas stuff, I figure the nastier it smells the better it has got to be lol
Car: 1988 rs
i would just like a little extra insurance, i will have a 540bbc with a manual transmission behind int.
would do you have to say about the metal fillings in the oil? is that common for new gears?
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
i used to work in a shop i did a lot of the preventative maintenence on the vehicles and ive removed 100's of rear diff covers and i have only seen very few that didnt have any small particles like that as long as theyre too small to pick out an idividual shaving i wouldnt be to worried thats just me.. one trick i used to see if there was a problem i would stick a decent sized magnet to the rear diff cover drive a few weeks pull the cover back off and if theres a layer of shavings on the inside were the magnet is more than maybe 1/16th to 1/8th of an inch thick depending on how parranoid u are then i would look into it... till then you should be ok
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
"what gear oil should i use for a detroit locker?"
any good top shelf gear Lube.
Car: 88 Firebird Formula 350
Engine: 355 mild cam stock TPI
Transmission: TH350
Axle/Gears: Moser 12 Bolt w/ 3:73's Eaton Posi
The manual says to use the recommended lube for the vehicle for the Detroit Locker. Detroit Locker owners manual.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I too have a Detroit Locker in my 9" and the guy that put it in for me said he couldnt use the ARP ring gear bolts I gave him. Something about them not being long enough or something.
As far as the shavings, I agree with the guy above. I do axle work at a dealership and shavings are normal. Pieces you can pick up are not. As long as everything is just thin shavings, its normal.
For gear lube, I have Ford 75-140 synthetic in mine. I used Ford becuase its on my bench at work and therefore is free. Any synthetic 75-140 would be good though.
let me nip this in the bud..the Detroit Locker takes NO SPECIAL Lubricants
just use what your vehicle/axle manufacturer recommends
(I have a Locker, and The manual) so any top shelf gear lube works
like posted
i drop mine with every summer, it's cheap, and makes me feel good.
