Trans Mount
Old May 16, 2010 | 07:38 PM
rvega022's Avatar
Trans Mount
I have a 86 IROC-Z with a 700R4 transmission, when I go from Park to Reverse I hear a "clunk" noise. I also get the noise when I shift from Neutral to Drive.
Could this be the Transmission Mount?
Since the transmission is working just fine with smooth shifts from 1st to 4th gears.
Old May 16, 2010 | 07:49 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Trans Mount
I would suspect the U-joints on the driveline first. When were the last lubed or replaced?
Old May 16, 2010 | 08:00 PM
rvega022's Avatar
Re: Trans Mount
I purchased the car about 1.5 years age as a project car. I haven't touched the u-joints yet. I'll try greasing them first.
Old May 16, 2010 | 10:43 PM
Drew's Avatar
Re: Trans Mount
If the U-joints are original equipment they're not greaseable. Take a look at the yokes, if they have spring clip retainers then look and see if there's a zerk. If you don't see clips retaining the bearing cups then they're the original U joints.
While you're under there, put a floor jack under the tailshaft of the transmission and pump it up slowly while watching the transmission mount. Usually if the car doesn't already have a polyurethane mount, the rubber will be rotten, and the two halves will be ripped apart. Usually the best indicator of a broken mount is when the transmission shifts into 2nd gear at WOT the transmission slams into the side of the transmission tunnel.
Old May 17, 2010 | 06:48 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Trans Mount
Old May 17, 2010 | 07:05 AM
Twin_Turbo's Avatar
Re: Trans Mount
It's not uncommon for the threads in the subframe to be stripped out and the bolts for the crossmember to sit loose. It's an easy check and easily fixed by tapping to an oversize
Old May 17, 2010 | 07:10 AM
rvega022's Avatar
Re: Trans Mount
Guys,
Thanks for the great tips I check them out this afternoon.
Old May 18, 2010 | 06:05 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: Trans Mount
OK i got a problem i keep breaking trans-mounts
i have the factory mount on the car to about a year ago when i put nitrous on the car that mount was just blown apart so i went to autozone and got a other rubber one for $5 and it was fine to i took the nitrous off the car now i break a mount almost every month. i checked everything even changed the motor mounts and the driveshaft and U-joints
Old May 18, 2010 | 06:36 PM
87350IROC's Avatar
Car: 87' IROC
Re: Trans Mount
It is a known problem with these cars. A damaged trans can increase this problem. Most people solve the issue with a polyurethane trans mount.
Old May 18, 2010 | 07:20 PM
Twin_Turbo's Avatar
Re: Trans Mount
which is a bad idea unless you like breaking the case.
Check driveline angles, they are a common reason for mount failures
Old May 19, 2010 | 01:20 AM
87350IROC's Avatar
Car: 87' IROC
Re: Trans Mount
Running a poly mount? Never heard of anyone having problems. But that doesn't mean it doesn't happen.
Old May 19, 2010 | 04:14 AM
Twin_Turbo's Avatar
Re: Trans Mount
bad driveline angle + poly mount. note, this is a next to brand new transmission
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
